Run my fridge on gas
Submitted: Tuesday, Jul 29, 2014 at 09:18
Can someone email me with some advice on how to get my fridge running on gas i have attached a picture of the fridge grsdashby@gmail.com
Jayco 2002heritage
Reply By: Glenn C5 - Tuesday, Jul 29, 2014 at 09:39
Can't see the
pic 444
536772
Follow Up By: 444 - Tuesday, Jul 29, 2014 at 09:45
820987
Follow Up By: Glenn C5 - Tuesday, Jul 29, 2014 at 09:48
No its not working 444. You might need to have a look at the insert images and files button. Cheers
820988
Follow Up By: 444 - Tuesday, Jul 29, 2014 at 09:50
Can you please email me
grsdashby@gmail.com
820990
Reply By: Green Rv - Tuesday, Jul 29, 2014 at 10:36
Hi 444
below is a direct link to dometic fridge manuals if you have a dometic the fridge part number is inside the main fridge either inside door or on the back wall then you can select the right manual
if you think its a fridge issue please let us know
http://www.dometicrvcentre.com.au/userguides/product-instructions
hope this helps
Adam
536775
Reply By: Batt's - Friday, Aug 01, 2014 at 13:10
If you're having trouble and are unsure of what to do play it safe and go to a caravan dealer and their mechanic will probably
test and
check the whole system for leaks etc and show you how to operate it correctly it might cost a couple of dollars but it is better than blowing something up.
536957
