No spark on my 1989 Rodeo
Submitted: Tuesday, Jul 29, 2014 at 08:37
ThreadID: 108923 Views:1745 Replies:3 FollowUps:4
Hi kids, I've seemed to have lost my spark on my 1989, 2600 DLX ute. (No spark at any of the plugs). Have power at the inside fuse and at the ign coil and the ECM relay clicks when the key is turned on. (By the way where is the ECM located? Under the engine bay fuse box?) I've tried to get a workshop manual and I ended up sending away for one. Any suggestions, besides setting fire to it? Regards, Gerry.
Reply By: Member - Tony H (touring oz) - Tuesday, Jul 29, 2014 at 10:05
I'd be checking/suspecting the 'Crank Angle Sensor'
AnswerID: 536773
Follow Up By: Gerry G - Tuesday, Jul 29, 2014 at 17:59
Hi Tony H, I'm still waiting for my manual to arrive so I don't know my way around under this bonnet yet. Where is the "crank angle sensor"?
Thanks, Gerry.
FollowupID: 821010
Follow Up By: Member - Tony H (touring oz) - Tuesday, Jul 29, 2014 at 18:28
Bearing in mind Im not familiar with your engine.... it would be either on the front of the engine around the crankshaft pulley/timing case or it could be around the flywheel/bell housing area.
The 'kick panel' aonther contributor has mentioned is the plastic panel under the dash beside your right foot OR it could be the passengers side .... so beside the passengers left foot.
Best wait till your manual arrives have a read ....if in doubt consult your local mechainic
FollowupID: 821017
Reply By: Member Kerry W (WA) - Tuesday, Jul 29, 2014 at 11:44
Also check for oil in the distributor.
Kerry W (Qld)
-Helen Keller
AnswerID: 536778
Reply By: bluefella - Tuesday, Jul 29, 2014 at 15:04
I had one, same thing turned out to be a small relay behind the drivers side kick panel. Could be your problem?
AnswerID: 536788
Follow Up By: Gerry G - Tuesday, Jul 29, 2014 at 17:54
Hi Bluefella, don't want to sound dumb but what is the "kick panel"? Thanks, Gerry.
FollowupID: 821009
Follow Up By: bluefella - Tuesday, Jul 29, 2014 at 19:10
Hi Gerry
It's the plastic panel that is on the drivers side near the accelerator.
FollowupID: 821020
