clutch issues
Submitted: Saturday, Jul 26, 2014 at 17:09
noddy77
Hi all, I have a 95 turbo diesel rodeo, my problem is the clutch takes up very low on the floor, like foot flat car still drives off.
I have replaced the slave cylinder but made no difference, does anyone have any ideas, do I need a new clutch?
Reply By: Member - mechpete - Saturday, Jul 26, 2014 at 17:31
if there is no fluid leaks , not sure if its adjustable ,if not put a clutch init
unless the slave was faulty ,eg leaking ,waste of money an time
cheers mechpete
536642
Reply By: Steve D1 - Saturday, Jul 26, 2014 at 19:31
At around that age of Rodeo, they had a habit cracking the firewall where the clutch master bolts on. This allows the fire wall to flex, so when you push on the pedal, the wall moves more, and the fluid is pushed less. If so, the wall will need to be braced to fix it.
Steve
536646
Follow Up By: Hoyks - Saturday, Jul 26, 2014 at 21:09
Yep, our work one had a cracked firewall. We sent it to the dent knockers to have the firewall repaired and strengthened.
820835
