2003 nissan navara D22 zd30 turbo spill valve location ?
Submitted: Friday, Jul 18, 2014 at 12:27
turbo1600
HI, any body know the location of the spill valve on the `03 navara zd30 ? for some reason i just cant find any info on it ..
thanks.
mark k
Reply By: olcoolone - Friday, Jul 18, 2014 at 17:32
Turbo spill valve??????
There is a spill valve on the back of the injector pump between the four injector lines, it's a round thing with two wires that run up to the electronic pump controller mounted on the top of the pump.
Your not talking about the swirl control valve?
536263
Follow Up By: turbo1600 - Friday, Jul 18, 2014 at 18:31
hi, the scan tool definately says spill valve error.
not swirl .
mk
820332
Follow Up By: olcoolone - Friday, Jul 18, 2014 at 19:10
Maybe the valve but more then likely it could be the driver (ECU) that controls the operation if the valve.
Check it with a multimeter and see if it has a couple of ohms across the coil.
820334
Reply By: Hoyks - Saturday, Jul 19, 2014 at 18:42
Spill valve as in the turbo dump valve or waste
gate?
On a diesel they are generally located in the turbo turbine housing and have a pressure actuated valve that dumps excess boost into the exhaust dump pipe just down stream of the turbo.
536302
Follow Up By: olcoolone - Sunday, Jul 20, 2014 at 09:15
Spill valve is to do with the injection side not turbo, waste
gate is on older turbo's with non variable vane turbos.
820393
