2007 Rodeo turbo diesel de rating
Submitted: Tuesday, Jun 10, 2014 at 13:45
Mel D
Hi all, after some advice, i have a 2007 Holden Rodeo Turbo Diesel. i have had it at the mechanic a few times and an undefined code comes up.
My Problem,
It keeps derating... it loses power (the engine keeps running) but wont rev over 1000. i turn it off and back on and is good, engine light stays on for a few days.
has anyone else had this problem?
Reply By: pepper2 - Tuesday, Jun 10, 2014 at 14:47
What is the code ?
534133
Follow Up By: Mel D - Tuesday, Jun 10, 2014 at 18:50
The fault says undefined.. im not sure what that means.
817707
Reply By: Ross M - Tuesday, Jun 10, 2014 at 19:49
Has the mechanic or anyone else checked the fuel filter for contamination?
Do you know when ie, how many KM's ago the filter was replaced?
When running, has the fuel pressure been checked by fitting a gauge to the
water drain point and turning on the filter drain?
Many of the earlier ones had the fuel pressure regulator develop a fault and low fuel pressure is the result. Fuel pressure should be around 6 psi.
If faulty ie, low pressure, hardly any, then this may be what you require.
I think this is correct, I have not purchased one and this is the info received from someone else.
Part number of removed pressure regulator: GM8-98042316-0
New Kit
Part number: GM8-98145453-0
Part name: Kit Fuel Pressure 4JJ1
This is a KIT for the replacement of the above regulator. The regulator bolts onto the rear of the High pressure pump.
It may be the problem. Just a bit hard to tell from this distance.
534150
Follow Up By: Mel D - Saturday, Jun 14, 2014 at 12:13
Ross,
Fuel filter was changed last week and apparently it was clean.
haven't had any pressure checked but the codes that came up this time was saying low pressure.
will ask them to check that for me.
This is the first diesel i have owned and dont know of a good diesel mechanic
817921
Reply By: ROBBS GONE BUSH - Wednesday, Jun 11, 2014 at 21:05
Hi Mel,
Your symptoms are exactly what i experienced with my Nissan Terrano II 2.8 Inter-cooled Turbo Diesel.
It turned out to be a dirty MAF (mass air flow sensor), once this was replaced back to full revs.
If cleaning does not fix then you will have to replace.
cheers Rob
534211
Follow Up By: Mel D - Saturday, Jun 14, 2014 at 12:14
Thanks, Will get that check aswell, the revs come back to normal once i turn it off and turn it back on... very frustrating
817922
Reply By: Alloy c/t - Thursday, Jun 12, 2014 at 14:12
I actually had the same problem in my 05 Rodeo dual cab turbo diesel a few yrs ago ,, turned out to be a combination of :
water in the fuel trap : dirty MAF sensor and of all things that the AUTO gearbox fluid and filter had NEVER been changed /serviced even though the log book had been 'ticked' ,,,, process of elimination with plenty of frustration finally resolved the problem ,,,
water in the trap an easy fix , MAF sensor an easy fix and if it continues try the BOX……..
534238
Follow Up By: Mel D - Saturday, Jun 14, 2014 at 12:17
Hi Alloy,
Thanks for the info,
mine is a 5 speed so dont think the auto gearbox would be a problem for me. apparently fuel trap seems good will look at the MAF? sensor
817923
Reply By: Tonyfish#58 - Friday, Jun 13, 2014 at 17:03
Rodeo Fuel Issues
Try this post I did a few years ago
Hope you find the issue, I have had no issues since now 170k
Regards Tony
534294
Follow Up By: Mel D - Saturday, Jun 14, 2014 at 12:19
Hi Tony,
thanks for that, i'll check it out.
817924
Reply By: Mel D - Saturday, Jun 14, 2014 at 12:08
Thanks for the info guys, I have taken it to the mechanic again to get some codes. this is what came up
P0089 Pressure regulator
P1093 fuel rail pressure to low
P0093 fuel system leak detected lager leak
P1094
Fuel rail pressure system low
P0087 fuel rail system pressure low
Any thoughts on what it is that would need to be replaced?
534332
