Rim offset
Submitted: Friday, Jun 06, 2014 at 16:38
ThreadID: 108140 Views:3048 Replies:6 FollowUps:0
I have been through the various threads and Google and cant find a definitive answer. I have a 1993 HZJ75 Troopy currently fitted with Sunraysia rims and 31 x 10.5-16 six stud rims. I told the rim offset is confined to Troopys only. My issue is i can't find out what the offset is. I have a couple of spares off a ute but don't want to go bush if they are going to scrub. Can anyone explain the offset and how to check it?
Reply By: Rod W - Friday, Jun 06, 2014 at 16:47
Its Zero off set
AnswerID: 533860
Reply By: Steve - Friday, Jun 06, 2014 at 16:47
http://www.towingandtrailers.co.uk/shop/132/137/167/index.htm
there you go mate - should cover it
AnswerID: 533861
Reply By: Ross M - Friday, Jun 06, 2014 at 17:15
Ian
Get a piece of paper or thin cardboard.
Cut a strip the so it's length goes from the outer rim edge to the inner rim edge.
Fold it in half.
That half line is the rim centre.
Tape the strip onto the inside of the rim so each end is in place ie, to ouert and inner edges.
Use a flat piece of metal/cardboard/plastic/rule and place it's edge onto the inner face of the rim centre.
Slide it out until it touches the strip.
Where that line touches will be towards the outside of the rim if a positive offset.
If no offset the line will touch the centre of the strip.
If the line touches the rim inwards of the strip centre it is a negative offset rim. Any distance in mm. from the line to the strip centre is the amount of offset, be it pos or neg.
Ross M
AnswerID: 533863
Reply By: Member - Charlie M (SA) - Friday, Jun 06, 2014 at 20:39
I think you will find the rim is 15inch not 16inch
Rim most likely will be a 15x7 inch, but may be 15x8 inch
Charlie
AnswerID: 533876
Reply By: Member - Brad S7 - Friday, Jun 06, 2014 at 22:13
If go on the Mullins wheel website and select steel wheels open up their brochure, just find your vehicle and it will have all the details
This is not a rehearsal !!!
AnswerID: 533889
Reply By: 7739ian - Saturday, Jun 07, 2014 at 11:06
Thanks all - simple when it's explained.
Cheers, Ian
AnswerID: 533914
