Thursday, Feb 26, 2004 at 12:52
Synergist.
The differance between cranking and deep cycle, so I was lead to belives is as follows.
Cranking batteries are designed and built to deliver a large amp delivery I.E. about 80 to 100 amps a short period of time, about 10 or so second, to start the engine and allow the alternator fitted to the vehicle to take up the load of poweri9ng the vehicle and replace the charge taken from the starting battery as quickly as possible, so as to be ready for the next starting cycle. This is why starting batteries are rated in CCA's ( Cold Cranking Amps) and not Amp/Hours.
Deep cycle batteries are designed and built to supply a constant "light current" over a longer period of time and this is measured in Amp/Hours. My 80 Amp/Hour battery is rates 4 amps @ 20 hours. If you take a higher level of current from the Deep Cycle battery it shortens the usage time considerably.
I.E. 8 amps per hour will only eaqual about 8 hours of use, not 10.
However, you should not discharge the battery to this level, At most you should only discharge to 50% of capacity and the recharge, and this will have a life limiting aspect on your deep cycle battery. A battery life is limited by the numer and depth of discharge/charging cycles. The deeper the discharge between charges, the lesser the number of cycles that you can achieve.
Most battery manufactures reccomend a discharge level of about 25% of capacity before recharging, to atain the highest number of cycles available for a deep cycle battery
Another point to remember is battery maintance. Regular cleaning, to prevent parasitic discharge between the terminals, topping up with disatilled or de-ionised water, (NOT TAP) and kept cool and
well ventilated to disperse volitile gasses produced during charging.
Also, no not store the battery in a discharged state, as this allows the plates to sulphate and prevent adaquate recharging to full capacity, and thus slowly ruining it.
I would suggest reading a couple of battery manufactures sites re recharge cycles etc, and the site operated by MEGAPULSE, as this give a lot of informanion.
Cheers Nick.
48202
