Electrical issue
Submitted: Tuesday, May 27, 2014 at 18:27
southy
Ok this one has me stumped.... I had a wire short out on the metal on hand brake this morning, this caused the lights, radio, UHF, indicators and central locking to stop working....... I have checked all the fuses they're all fine
Any ideas??
forgot to add its an old 89 Triton
Reply By: Ross M - Tuesday, May 27, 2014 at 19:01
Did you
test all fuses with a multimeter to
check integrity of the fuse? ie multimeter on ohms 200?
Maybe the fuse which has blown isn't one of the ones you have found yet.
533259
Reply By: HKB Electronics - Tuesday, May 27, 2014 at 19:52
You most likely have blown a fuse or a fusible link.
As above
check with a meter as sometimes it is hard to see if they are blown.
Also as multiple circuits aren't working I would subbest it is a fusible link that has ruptured.
Leigh
533265
Reply By: howesy - Tuesday, May 27, 2014 at 20:37
check battery,
mine has 2 fusible links and if one goes it takes out all those accessories
533266
Reply By: southy - Tuesday, May 27, 2014 at 21:32
Thanks guys will do
533276
Reply By: southy - Wednesday, May 28, 2014 at 15:33
Yep it was a fuseable link, not the ones off the battery but one tucked away on the drivers side just below the windscreen which had corroded
533321
