satlink 6906 sat finder
Submitted: Thursday, May 15, 2014 at 12:34
Member - wozza
hi would anyone know how set the optus c1 satellite into my satlink 6906 i have tried to enter the data in the add satellite menu the 156.0E cannot be entered ,there is no decimal on the key board.
Reply By: Dennis Ellery - Thursday, May 15, 2014 at 18:35
Hi Wozza.
I not long ago retuned my WS6906 to Optus D3 (where Vast lives).
This the way I did it – Deleted old Optus CI Channels from WS6960.
Locked the disk onto Vast Optus D3 (using other methods than the WS6960)
Connected WS6960 to the disk.
Turned it on – went to Channel Menu – select TV channel option – search for Free Satelite – press OK.
WS6960 then scanned in 1 Help channel plus 5 others.
I deleted the 5 other channels and only retained the Help channel to tune to.
Best of luck
532512
Follow Up By: Member - wozza - Friday, May 16, 2014 at 12:51
thanks i will try that,
mine is aWS-6906 but that should not matter.i thought the vast sat was optus c1.
815842
Follow Up By: Member - Rod N (QLD) - Friday, May 16, 2014 at 13:20
You are both sort of correct. Some (most) VAST channels are on C1 and some are on D3. They are co-located at 156 deg E so it will not matter which one you search for.
Try just entering 156 and ignore the .0
815844
Follow Up By: Dennis Ellery - Friday, May 16, 2014 at 19:49
What I should have said was that my 6906 finder was previously set up for the Aurora system and still worked ok on the VAST system until a while ago. I retuned it to the VAST system as described above.
815869
