LED internal bulbs for caravans.
Submitted: Tuesday, May 06, 2014 at 17:44
Member - G.T.
My van has 19 internal halogen lamps mounted as down lights. They have the G4 type of bulb, two pins protruding from one end, which push into a corresponding female fitting into the lamp base. They have a 10 Watt output.
I would like convert these to LED , but are not sure what to purchase, as there are many brands out there, at varying prices---- $5.00 to $16.00 ea. Will be a tad expensive if I decide to replace them all at once at the $16.00 mark. May be I will do it gradually, a few at a time.
Also what does the 10 Watt output convert to into either Kelvin or Lumens which is mentioned in the advts. I am not sure what Kelvin or Lumens are exactly , all I want is to have a replacement LED with the same light output.
Is there anyone out there can help me, I don't mind if you are a business member or person or not. All suggestions gratefully received. Regards G.T.
Reply By: Dennis Ellery - Tuesday, May 06, 2014 at 19:13
I purchased LEDs from ledshoponline.com
Their MR11 line of bulbs fit the G4 downlight socket and they have these in 6, 9 and 12 SMD configurations.
They say that their 9 SMD units give as much light as a 10 w Halogen
When I purchased
mine in 2009 the largest I could get was the MR11 configured to 6 SMD.
At the time I paid $19 each. I would buy a 9 SMD and a 12SMD and trial them.
531988
Reply By: - Johny boy (NSW) - Tuesday, May 06, 2014 at 20:46
Hi GT,
I replaced all of
mine which are the same type from a place called Vanline they are at 6/11 swaffham rd Minto in SYD (02) 9603-9200 I think I only paid about $5 each for those, Hope this helps?
John.
531996
Reply By: MEMBER - Darian, SA - Tuesday, May 06, 2014 at 20:56
I've just replaced our bed reading lamp globes in the van (the originals are MR16 format 10W halogen - all others lights in the van are LED - I did this to avoid the high heat levels of the halogens) - Bunnings have heaps of them to choose from - I went with a 5.5W - 310 lumen 'Brilliant' brand, designated as MR16/GU5.3 - about $9.50 each. While flagged as 'warm white' they are extremely
bright and my guess is they are brighter than the original halogens - a further guess is that 3W-4W might be an equivalent for the 10W halogen.
My readings suggest that trying to evaluate light values across the various globes and modes based on W = brightness is hopeless - very much a 'suck it and see' scenario. BTW - Bunnos did have some 3W's there on a run out special for $5.
531999
Reply By: Gone Bush (WA) - Tuesday, May 06, 2014 at 21:54
You can get MR11 LED downlights on Ebay for as little as $2 each.
532006
Follow Up By: rooster350 - Wednesday, May 07, 2014 at 15:55
Purchased ours on Ebay , did all of the lights in the van for around $20 or so...came from China (what doesnt these days) and have had no trouble with them...cheers
815234
Reply By: Member - Tony H (touring oz) - Wednesday, May 07, 2014 at 08:23
Just remember that when deciding on the globe to buy...'warm white' is a yellowish white & 'daylight' OR 'cool white' is a brilliant white (my choice)
532032
Follow Up By: AlbyNSW - Wednesday, May 07, 2014 at 08:51
As a side note I trialled some warm white and cool white LEDs over
Easter in the outback and the cool whites had bugs swarming to them whereas the warm white had next to none
815215
Reply By: Member - Rosco from way back - Wednesday, May 07, 2014 at 09:03
Kelvin relates to the temperature range of the light (warm white, cool white etc) and Lumens is a measure of the light output. So to get a similar result from LED lights you will need to match these figures if possible.
532035
