Tuesday, Apr 29, 2014 at 22:53
The fact is these common rail diesels are nowhere near as tolerant of fuel contamination as the earlier mechanical pump diesels.
The old diesels you could throw significant quantities of petrol or other solvents in the tank and they would run fine and have a high probability of no ill effects.
Solvent or petrol contamination can not be filtered by any means.
Some of the common rail diesels are reported to be more sensitive than others to solvent or petrol contamination.
The older diesels would tolerate very small amounts of water passing in the fuel, but mostly had adequate water trap filters operating in a low pressure fuel line.
The common rail diesels are almost completly intolerant of water in the fuel and the the filtering and water traps ( in the view of many) are not adequate considering this intolerance.
One poster of another
forum was furiuos......he had purchased a new small excavator, that had a near identical engine in to that in his near new ute......these two machines where similar in dollar value...but the excavator had a very comprehensive multistage filter..factory standard...his ute had what he and others consider a token effort filter.
As far as being a one in a million chance....if that was so there would be only 2 D4D hiluxes in
brisbane that have had a common rail related fule system failure.
Well there is a bloke I know just arround the corner that has had a major fuel system over haul paid for by a fuel company...because toyota refuesed to take responsibility...he was fortunate..he baught all his fuel from the same company on a fuel card.
The D4D hiluxes DID have issues with their early injectors that they systematically tried to deny responsibility for.....my brothers best mate baught an early D4D hilux new and had fuel system issues quite early on....not disasterous but not running how it should.....at first the dealer tried to fob him off.....untill he made some phone calls and the dealer was informed who he was, his long term reputation as a mechanic and his long term relatioship with toyota as a mechanic.....the injectors where replaced at no cost......most do not have that sort of leverage.
It is the view of many that while Toyota have addressed the early...plainly substandard ...injector problems, their injectors are still not as robust as some of the others.
As for the thousands of vehicles out there having no problems at all........of course there are thousands out ther having no problems...because they have not been put in the situation where a failure may occur.
Even the dodgyest products you could find...the manufacturers will be able to point out that there are thousands of units out there "operating perfectly"...that can not be taken as proof that there is not a problem and the many failures did not occur.
There is a real problem that Common rail diesel is still a new technology......being offered for only less than 10 years in the volume market, makes it a new technology.
While some of the better manufacturers may have had the time, will and volume of units to perfect thier product others may not yet have been able to do so...in addition, the rest of the motoring world including the fuel suppliers may not have improved their game to permit the common rail diesel to be as reliable as it realy should be.
For my part I will be staying away from common rial for a while yet......I will continue to drive my crude old diesel burner for a while yet. And when I do replace it I will be very serioulsy considering a petrol motor.
The reasons for running a diesel are not as convincing as they where in the past.
Electronicaly injected petrol motors have been proven to be long term reliable, are more efficient and powerfull than they have ever been and their fuel systems are cheaper to repair and service.
531507
Follow Up By: olcoolone - Wednesday, Apr 30, 2014 at 21:07
Hino, used common rail in the mid 90, Mercedes and a few others in a few year after and Toyota first started using it in 2000........ Not really new technology.
It nearly 20 years old in automotive and nearly 100 years old in heavy industries like rail and marine.
814578
Follow Up By: The Bantam - Wednesday, Apr 30, 2014 at 22:22
Common rail diesel fuel injection in the form we currently find it with its incredibly high injection pressures is a very new technology in automotive terms.
Common rail petrol fuel injection has been arround for a very long time...but that is a whole different story.
The critical matter with the current form of diesel common rial injection is these incredibly high pressures present at the injectors.
It is these very high pressures that allow the large power gains and reduction in emmissions, by permitting injecton timimg at late parts of the compression cycle.
It is these incredibly high pressures and the very narrow clearances that make common rail injection so vunerable to damage from contaminated fuel.
814580
Follow Up By: mikehzz - Wednesday, Apr 30, 2014 at 22:34
What do you call new? My 10 year old Jeep with Merc engine is a CRD coming up towards 200,000kms....
814581
Follow Up By: The Bantam - Wednesday, Apr 30, 2014 at 23:18
As far as automotive technology, 10 years is new.
And merc have always been one of the leaders in diesel technology......don't expect some of the lesser brands or less diesel engine volume brands to be as
well sorted as merc.
When you have over 300 000 on the original injectors tell me.
814583
Follow Up By: olcoolone - Thursday, May 01, 2014 at 19:55
Suposse some are stll trying to get their head around the new hi tech 60 series with the new hi tech 12HT........ It will never be reliable and they have too much power..... It's a time bomb waiting to go off.
I'll stick to my 55 series, atleast i can work on it myself!
Can't wait to read the posts on forums in another 40 years.
So The Bantam....... How many centres old does something have to be before it't not new technology and you accept it?
814641
Follow Up By: mikehzz - Thursday, May 01, 2014 at 20:48
I think you might have meant the 3 litre Nissan there... :-)
814651
Follow Up By: The Bantam - Thursday, May 01, 2014 at 22:38
It will be a proven technology when it shows its self to be reliable.
when we do not have manufacturers bringing vehicles like the 3 liter diesel patrol and toyota with their injector problems to market.
When it is not a regular occurance that the product fails dramaticly due to relativly minor factors that realy can be expected...like a little water in the fuel or solvent contamination....or simply from overheating.
OH BTW..has anybody had to clean diesel bug out of a common rail fuel system.....one of my brotherinlaws got a bad dose of diesel bug in his navara......that took a bit of cleaning out.....but it did not require replacement of the pump or injectors......but that was an old style fuel system.
The thing is fuel contamination remains a reality in the diesel supply and not just in remote areas.
If you want to talk in tems of consumer law.....the product is not fit for purpose because it does not properly account for fuel quality.
It would be a start if they fitted a fuel filtration system that reflected the sensitivity of the injection system to contamination and the high probability of fuel contamination.
Then you have to account for certain manufacturers proven inability to refine their product and make it reliable.
Ford for example have been making cars since 1903...they still cant manage to make a door handle that is adequate for the purpose.
Stewart and Binny, applied for the first diesel ( they did not call it Diesel engine) patents way back in around 1890...and untill the common rail injection system the engine remained more or less the same with some minor changes.
Rudolph Diesel did not build his first prototype till 1893....it was more than 10 years till someone screwed a turbo to a diesel engine.
10 years is not very long in the history of motoring.
814656
Follow Up By: olcoolone - Friday, May 02, 2014 at 10:58
QUOTE "If you want to talk in tems of consumer law.....the product is not fit for purpose because it does not properly account for fuel quality."
Consumer law only comes into force when something doesn't perform or conform to suit the standards.
All fuel companies would be supplying fuel at the acceptable quality and standard as documented in law, what happens after this is nothing to do with Toyota or the fuel company..... both parties have no control over this.
Bit like owning a Ferrari with big ultra light rims and them complaining under law that the rims are not designed to withstand the impact of corrugated dirt roads when traveling over 160kph for prolonged periods.
There is nothing wrong with the filtration systems of current vehicles as long as the vehicle is used and operated within the standards.
The filtering system is very good as long as the fuel supplied meets the standards in which it would. If the fuel doesn't meet the standards after it has be produced and delivered to the reseller/retailer them that's between the reseller/retailer and the consumer....not the vehicle manufacture or fuel producer.
It's the governments of the world who force manufactures to produce cleaner more fuel efficient vehicles that have to meet stringent targets.
The vehicle manufactures would be happy to still produce simple mechanical fuel injected turbo charged vehicles...... but they (the governments and people of this world) would not accept it.
814671
Follow Up By: The Bantam - Friday, May 02, 2014 at 17:44
It's plain and obvious that the care companies don't care that there is a difference between what is specified as the fuel standard or what should be the quality of the fuel.....and the reality.
Because their legal people have determined that they will not be paying the bill.
They don't care that the consumer is inconvienienced at best, likely to bear a very large cost of a fuel system rebuild if they cant prove where they baught their fuel and at worst.....if they are traveling remote stranded with the very real risk of death.
If they did care they would be installing comprehensive fuel filtration as is found in the earth moving and heavy transport industry.
The product is not fit for purpose.
814727
Follow Up By: Alan S (WA) - Monday, May 12, 2014 at 22:19
While I agree that CRD diesels don't like dirty fuel, but at OC said they are designed to accept a standard defined quality of fuel.
To say that to accommodate or to be "fit for purpose" being for remote travel car manufacturers to make their product comply is plainly ridiculous.
You would be making 100% of car buyers pay for features that are required only by a small few.
As I have mentioned in a previous post, fuel is required to comply to standard, if what you buy is not at a standard it is the the fuel suppliers responsibility.
If you don't trust the supplier, the yes, spend your money to take precautions that suit your purpose. But you are wanting a third party totally unrelated to supplying you fuel to provide protection.
Get real.
815636
Follow Up By: Alan S (WA) - Monday, May 12, 2014 at 23:37
Bantam
There has been a couple of threads recently where you and others have criticised the quality provided by service providers. Now for some reason there is a lack of criticism of a provider of a product, and instead trying to place the blame on some one else.
In the context of the previous threads, it's like blaming the parts suppliers for the poor installation.
To be consistent you should start to consider the fuel supplier. How hard is it for a fuel station to install suitable delivery system, inc filters, and to supply a quality product.
815640
