Oil leak.
Submitted: Saturday, Apr 26, 2014 at 19:18
ThreadID: 107478 Views:1783 Replies:4 FollowUps:2
Hi I 3.2 diesel Pajero 2010 model that has a oil leak on the driver side that run down on to the sump plug and drips any idea were it would come from,it has done 90,000 km.John.
Reply By: Ross M - Saturday, Apr 26, 2014 at 19:38
Possible oil filter leak or not tight on housing?
Sump loose?
If turbo on that side, OIL Supply hose crimp not tight.
Oil leak from head/block ie, head gasket. Possible head not tight enough or gasket has failed.
A good look with a bright LED torch should find where from. LED torches will reveal things dull torches don't show.
I would have to go look at one to say more.
AnswerID: 531286
Follow Up By: Member - 2517. - Sunday, Apr 27, 2014 at 08:40
Thanks for that.
FollowupID: 814310
Reply By: patsproule - Sunday, Apr 27, 2014 at 06:18
Most likely to be the oil pressure sender.
AnswerID: 531303
Follow Up By: Member - 2517. - Sunday, Apr 27, 2014 at 08:39
Thanks for that it sounds a easy fix.
FollowupID: 814309
Reply By: Member - ironJosh - Sunday, Apr 27, 2014 at 19:33
Could be coming from the Pajero badge...
:-P
AnswerID: 531360
Reply By: olcoolone - Monday, Apr 28, 2014 at 09:07
Has your Pajero got the 5/10 year Diamond Advantage warranty, if so take it to you Mitsubishi dealer for a fix.
AnswerID: 531397
