Lock for caravan drawbar
Submitted: Thursday, Apr 24, 2014 at 11:04
Brian
was shown 2 types of locks yesterday for caravan draw bar , one was like a ball that fits up inside the caravan coupling and the other like a frame that covers the top of the coupling . Which is the best option please ??
Only will keep out the honest thieves !!
Brian
Reply By: Sigmund - Thursday, Apr 24, 2014 at 11:45
The frame should also work to lock the coupling together whereas the ball won't.
531110
Reply By: Member - 178 - Thursday, Apr 24, 2014 at 12:57
I have used a hitch helmet for some years when towing a boat and when boat parked at
home. However I do not have anymore use as it will not fit offroad hitch on camper trailer. It is still in good condition in
Brisbane. Of course you will need to prevent coupling from being unbolted from drawbar. I also used a locking pin through towbar instead of standard pin as I didnt want to return to ramp and find trailer missing
https://www.whitworths.com.au/main_itemdetail.asp?cat=138&item=91169&intAbsolutePage=1
531114
Reply By: moamajohn - Thursday, Apr 24, 2014 at 13:39
Brian
mine is from Autobarn @ $ 60 for the lockable pin to pass thru the towbar to lock the goose neck and the other bit comes up form under the big nut and covers it and it has 2 hardened shafts that come up either side of the coupling and you fit a hardened female bracket over the holes the shaft has indentations so when you push it hard onto the top of the towball coupling and lock it ,thats it.I have had them for 10 years for my works trailer.I lost the key once and it took me 5 mins with a 6 foot crowbar and mash hammer to get it off and it was wrecked .Cheers
531115
Reply By: Member Boroma 604 - Thursday, Apr 24, 2014 at 17:01
Gooday,
You should be aware that a lock on the coupling is only going to slow down the Buggers, what they do is shackle the safety chain, or chains, short, drop them over the tow ball of the thieves vehicle form until they get clear of where they stole it and then get out a cordless grinder, if the hammer does not work, and hitch it up properly and off they go.
I have a Klampit Wheel clamp but they like most other precautions only slow down the experts. If you are able to concrete an anchor in the ground where you store it and put some decent chain around the axle they will most likely be too lazy to get under there and look for something easier.
Boroma604.
531123
Reply By: Shaker - Thursday, Apr 24, 2014 at 17:54
Either will suffice for insurance purposes, if parked in an unlocked yard or street.
531126
Follow Up By: Brian - Thursday, Apr 24, 2014 at 21:28
Thank you everyone , you really are a wonderful bunch
814160
