Monday, Apr 14, 2014 at 23:15
Not sure where you are getting your information from..
Montana and Monterra appear to have a bigger screen than 276 - Montana/Monterra is quoted as 10.2 cm diagonal, 276 is 9.5 cm diagonal..though 276 has more pixels, but less colours..not sure if any of these are significant/of any consequence in real world.
You can also customised the map screen on Montana and Monterra (and most if not all the Garmin handhelds) to show data fields much the same as 276 - example below...
Montana
Montana
Monterra
Monterra
(ignore elevation - haven't calibrated barometre:)
With the Monterra (not sure about Montana) a single press of the small arrow next to the data fields makes them disappear so you get full map view (and visa versa) - much better system than the old fashion 276c :)
OziExplorer (CE (e.g. Hema Navigator) and Android) also has the capability to show customised data fields next to the map (don't think they are "see through" but not sure that is essential), using Ozi Screen Designer..so no way it is unique to 276c.
May people are running android tablets/Ipads (+ozi etc) in cars so could be an option. You could have Ozi running on the Monterra/any android tablet/phone with almost the exact same screen as 276 (i.e. 4 data fields plus map)
My TwoNav has data fields on a separate page (but you can add them to main screen) which works fine - prefer to have whole map screen myself with no space taken by anything. A couple of button presses doesn't frustrate me (<1 second), though suppose if for some reason you have to flick back and forward frequently it could become a problem..maybe.
Anyway, I suppose my main point is that you can dwell on the 276c's good features if you want but it is approaching museum piece status (even if they put in a normal sd card). There are viable (and for some, much better) alternatives...impossible for me to pick them for you or anyone...but they do exist and the end result will be the same.
It can be hard to find the best, current option for required needs so I can understand the confusion being exhibited (by RM, me and others:). Some of the good features of many gps units and gps mapping applications can be
well hidden, it would however appear that some (including "experts") are not looking hard enough.
813514
