GME 4705 antenna
Hi all,
I just installed a new CB and installed a GME 4705 antenna with a 1.2m fibreglass antenna. For normal day to day driving I also purchased a 4701 58cm antenna.
When the smaller antenna is installed in the base, there is quite a lot of room between the antenna and the sides of the base.
The diameter of the 1.2m antenna is around 40mm and the diameter of the smaller antenna is around 18mm.
If it is raining the base will definitely collect water,
Just wondering if anyone else is running this sort of configuration and has the water collection caused any issues with the base?
Phil P
Reply By: Dion - Saturday, Apr 12, 2014 at 19:35
The larger base for 4705/4706 antenna have a drain hole below the threaded hole for the grub screw.
AnswerID: 530421
Follow Up By: Phil P - Saturday, Apr 12, 2014 at 21:05
Thanks, I had a closer look and the drain hole will do the trick!
FollowupID: 813329
Reply By: Member - Stephen L (Clare SA) - Saturday, Apr 12, 2014 at 21:19
Hi Phil
I have seen some people buy a second grey cover and cut a very neat hole in the centre, slightly smaller than the installed aerial, which acts as a very neat stopper.
Smile like a Crocodile
AnswerID: 530428
Follow Up By: Member - John (Vic) - Saturday, Apr 12, 2014 at 21:25
What he said :)
FollowupID: 813334
Follow Up By: Phil P - Saturday, Apr 12, 2014 at 22:14
I like that idea, will neaten it up.
Any ideas on where to purchase it? I couldn't see anything on the gme website
FollowupID: 813341
Follow Up By: Member - John (Vic) - Saturday, Apr 12, 2014 at 22:50
Use the one that came with it or go to Bunnings and find a large chair stop or similar.
FollowupID: 813345
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Apr 13, 2014 at 08:16
Hi Phil
I am an holidays at the moment, so I can not get the GME Part number.
Yes they are available as a spare part and sell for only a few dollars.
FollowupID: 813356
Follow Up By: Phil P - Sunday, Apr 13, 2014 at 22:49
I ended up drilling a hole in the original cap, very neat looking.
Just need a longer 1/4 inch grub screw to make it harder for would be thieves!
FollowupID: 813427
