Sunday, Apr 13, 2014 at 07:23
"This is not a fair comment on the air bags, even if you were to put in stronger springs ,were does the load go???? same place."
Yes, but at two spread out points . . . crew cab utes are the ones to watch apparently, maybe the Prado's fine with air bags used sensibly.
"The car should not be overloaded in the first place."
True, and maybe that can be worked on.
As a bushwalker, I can go out for ~ 10 days carrying everything (bar all my required water) in my backpack,
shelter, food, cooker, warmth.
I have done an 8 day walk with everything across a desert though, inc water, being ruthless on other items.
When we drive somewhere we usually take way too much stuff, and most of it un-used.
When walking, the only thing I take that I don't use (in general) is my
first aid kit.
Oh, for the OP, leaf spring pack can be boosted with extra shorter leafs (but ride will be harsher unladen, and articulation less offroad), a couple of longer springs might do the same thing but with more comfort.
Something like
http://www.etrailer.com/Vehicle-Suspension/SuperSprings/SSA15MTKT.html might be an answer too.
813352
