home made sun shelter
Submitted: Sunday, Apr 06, 2014 at 15:01
Cybermike
Hi, I am designing a sun
shelter to shade the top of a hard ute canopy for camping on. Sheltering from intense heat is more the priority than from rain (which is unlikely). A tarp will go over a frame. My experience with tarps are limited to one with silver on on the upper side & black underside, & am wondering if there is a better material such as canvas? In any case, I know the higher it gets, to cooler it will get on the surface to be shaded (as long as the sun doesn't shine in at an angle). Any ideas? Cheers.
Reply By: Nev (TAS) - Sunday, Apr 06, 2014 at 15:17
not sure if this is applicable or not in your situation but would a couple of decent solar panels do the trick. Get some shade and also ability to charge up batteries.
Rgds
529940
Follow Up By: Cybermike - Sunday, Apr 06, 2014 at 15:22
Good idea Nev to turn a problem into a resource, though I'm looking to have an area of maybe 4*3m to provide shade to the camping platform (top of canopy) even when the sun isn't directly overhead. Something to expand out to this size as the frame gets set up.
812769
Reply By: pop2jocem - Sunday, Apr 06, 2014 at 16:00
Bit confused mate. Are you looking to shade the camper that you will be sleeping/camping in or are you looking to shade a roof top tent or similar?
I have a camper body that we sleep and store our gear in and an aluminium decked roof rack that obviously acts as storage space, a mounting spot for our solar panel and shades the camper.
Before I added the ally decking I used to stretch one of those silver reflective tarps over the top. A lot easier not having to do that. The decking doesn't flap in the wind either.
Pop
529946
Reply By: The Bantam - Sunday, Apr 06, 2014 at 17:09
There are other materials than silver tarp...but the price goes up pretty fast.
White marine vinyl is pretty damn good.
But the old silver tarp is cheap and cheerfull...but you must buy
well..the realy cheap ones are just rubbish, they don't last long and the eyelets pull out.
I've had a good trot out of the austrail traps.
look for good
well reinforced corners and eyelets.
AND the trick is support the edges
well and at every eyelet and stretch em tight.. I mean tight.
I got a couple of em up here 24/7/365 and I get about 2 years out of a good one.
The problem with a portable arrangement is making something strong enough to give the tension.
529950
Reply By: Member - John and Val - Sunday, Apr 06, 2014 at 17:18
Hi Mike,
Since you want shade rather than
shelter from rain, have you considered using shadecloth - say 75% or higher. You could probably buy something ready-made, or if you have the necessary you could make something yourself.
Val.
| J and V
- Albert Einstein
529954
Follow Up By: AlbyNSW - Sunday, Apr 06, 2014 at 20:02
Agree with Val, I would be looking down this avenue as
well, you will buy a ready made shade cloth shade sale with eyelets etc all done for around $80 at Bunnings , 80% shading and will not hold in the heat or flap in the wind?just add poles
812789
Reply By: Cybermike - Monday, Apr 07, 2014 at 15:23
Some good ideas here - I'd not thought of the shadecloth though is something to try. Pop - the idea is to provide shade onto the top of a aluminium ute canopy which I sleep on (not in). I've had it with having to find appropriate trees from which to string up a tarp - so am looking to build a pop-up frame & put the tarp/shadecloth on that. It's way too hot to be in a roof-top tent, though use a mozzie dome if need be. Cheers.
530021
Reply By: RUMPLE AND FETISH - Monday, Apr 07, 2014 at 19:03
Hey Cyber
I make shadesails and do canvas work for a crust.
My advice would be to get 90 % shadecloth and form that on yer roof shade cloth is light weight dont crackle and rattle in the wind and the material these days is pretty strong
Go to a shade sail manufacturer they will have pieces of higher quality they may sell you
I would consider 70% material as a wall, stop flies and mozy s and will breath
530050
Follow Up By: Cybermike - Tuesday, Apr 08, 2014 at 23:30
How do you reckon this shadecloth would go on a dewy night - would it soak it or let it drip through?
813008
