Monday, Mar 10, 2014 at 18:34
you need to look at two different parts of the documents
50mm permitted
suspension lift.....subject to requirements
This will be in the section on
suspension
25mm lift from increase in tyre size
This will be in the section on tyres.
Its been a while since I waded thru the whole thing.
There was talk of a 50mm total at one time....I cant remember the details of how that played out....some of the states may have played that one differently.
The various states while more or less signing up to VSB14 have all seen fit to fiddle a bit.
For example....in QLD high mounted spot lights are permitted, but not in SA.
In QLD thay have always been red hot on prosecuting spotlights mounted above the bullbar...but in WA it seems fairly common.
Every other state and teritory makes it clear they do not permit extended spring shackles..even NSW...and it has been that way..."like For EVerrr"...but they are quite happy for you bto have em in NT.
We all had hopes of a consistent national vehicle mods polocy......I supose its better than it was.
810489
