Monday, Mar 03, 2014 at 17:33
What one puts there faith in can be a tricky question Krooznalong,
and I try not to get tocynical to quickly.
But would you put your faith in a
forum post from someone who rarely uses different tyres , gets a new set fitted , and says gee Whizz these are good which probably more reflects the fact that they now have something brand new.
I'd love to be in the position of some of those testers and have team changing all those sets of tyres and measure the results and do all the work.
Imagine having others set it all up and all you have to do is drive - one day maybe !
I can change 4 wheels by hand in 30 min now so its not to demanding - do use hand tools.
I think that you have to weed thru lots of stuff actually and make sure it smells right.
I've had a lot of experience weeding thru engineering specs and looking for duds, and having different sets of tyres helps & works out cheaper in the long run I feel.
One thing you can do is to simply get the specs and
check em out.
In the case of these latest tyres is easy to verify if they do have deepest tread , do they indeed have largest diameter and more rubber - I no longer get embrassed walking into a tyre
shop with Luggage scales in hand.
Measure the weight , percentage of carcass vunerable to punctures ,
check load ratings and plies.
(I have 2 sets of BFG AT one load D, other set Load E - many get caught by this on EBAY)
When they meet there claims here then its on to road reports and here
forum posts can have a helpful roll.
What you can't tell so easily is how they chip, squirm etc and reports from users help a lot here but then you need to have some idea of the type of driver , some clowns don't lower them and complain they chip to easily etc etc - you probably get the picture.
You also have to match them to your use pattern - for this latest set I'm getting its meant for surviving the harshess conditions - but I also love my classic BFG AT which are probably the best
for outback gravel work, and every week I put back on my set of D693 for surviving the local roundabouts.
Just as a side note - while I have already placed an order for a second set of these tyres I happened to pick up another mag "Overlander" today and its almost embrassing in the reports it carries for the choice I made from independant people so all is rosy at the moment.
810005
