latest hilux injectors
Submitted: Friday, Feb 28, 2014 at 09:50
Member - nick b
Can any one tell me what is the latest from toyota in regards to Hilux injectors on the current model , it has been reported by some the earlier models had problems with Aus fuel ? and needed replacing them regularly ??
Also any other problems like auto gear box ?
cheers nick
Reply By: HKB Electronics - Friday, Feb 28, 2014 at 10:08
Not sure about Hilux but Toyota changed the injectors on the Prado D4D around March 2008 to overcome problems with the earlier verions.
The big issue now is with the injector seats failing it seems. If they haven't been changed for the latest ones they should be as it can cause catastrophic engine failure due to deposits building up on the engine oil pump filter screen, causing oil starvation and consequent engine failure.
Leigh
527388
Reply By: ctaplin - Friday, Feb 28, 2014 at 10:19
Nick, I have an '09 Hilux D4D with 4 speed auto and so far no issues with the injectors but I found very early that when heavily laden, driving up very steep, continuous hills on the
Bloomfield track the transmission light came on and I had to stop and idle until it went out. I believe that people who use these vehicles to tow, experience the problem often but I wasn't going risk transmission damage so I fitted a PWR transmission cooler in series with the standard radiator trans cooler and have never had the problem again despite many, much tougher
hill climbs since.
Hope this helps...
Chris
527391
Follow Up By: Member - bbuzz (NSW) - Friday, Feb 28, 2014 at 11:23
People who tow should always fit an oil cooler to the transmission.
Look at pradopoint.com for the latest on the injectors, both for Prado and Hilux. Same story for both.
bill
809790
Reply By: TerraFirma - Friday, Feb 28, 2014 at 12:52
They have been changed to a Diamond tipped injector for a long time now and no problems I'm told. I have a 2005 model and did
mine at 120,000KM.s am up to 200,000Kms now and all is good. I only run
Caltex Vortex Premium diesel nowadays. The vehicle runs so
well and with 200,000kms on the clock I have only had to replace the water pump, timing belt and had the clock spring done under warranty.
527397
Reply By: Member - wicket - Saturday, Mar 01, 2014 at 13:09
For all things Hilux related go here;
http://www.newhilux.net/
527472
Follow Up By: Bazooka - Saturday, Mar 01, 2014 at 17:50
Interesting business model. A website which you can't view unless you sign up.
809890
Follow Up By: AlbyNSW - Saturday, Mar 01, 2014 at 19:07
It is a good site Bazooka, a wealth of information with over 40,000 members
809894
