Nissan navara d40 lev springs
Submitted: Tuesday, Feb 18, 2014 at 21:13
Have a nissan navara 2011 diesal twin cab and have found the rear
suspension lev spring completly failed and are strait with no curve at all 45000klm on clock and can not do a thing about it under warrenty so now have to look at replacing so thinking getting a more reliable set up like a old man emu with lift kit
any feed back would be great as going to get into 4 wheel driving hope hear from you soon
Reply By: Patrol22 - Tuesday, Feb 18, 2014 at 21:34
You'll likely get more advice over on the
Navara Forum. That said, I have a Ridepro set up that works for me......now done 125000km on it and still going strong, but the OME set up is equally as good.
526762
Reply By: Nutta - Tuesday, Feb 18, 2014 at 21:43
I put tough dog on my 2012 colorado, couldn't be happier, hasn't sagged after 3-4 months and carries plenty, also have the 300 kg springs in the rear, lifted around 50mm, around $1800 installed from opposite lock.
526766
Reply By: phil300 - Wednesday, Feb 19, 2014 at 12:30
I have a 2010 twin cab I put a set of Air bags in run them @ about 8psi all the time and up to 15psi with the van on about 250kg ball weight and tub full of gear.
Cheers phil.
526793
Follow Up By: phil300 - Wednesday, Feb 19, 2014 at 12:33
It is a Nissan STX should have said that above
809145
Reply By: Member -Dodger - Wednesday, Feb 19, 2014 at 14:33
I have a 3ltr BT50 dual cab and added these load plus Springs.
As my vehicle carries a reasonable load all the time they have been
well worth the effort.
See
Here
Mind you my ute springs had not sagged when fitted.
Cheers Dodg.
526799
Reply By: Ali Ree - Wednesday, Feb 19, 2014 at 17:37
526812
Reply By: Scrubrat6 - Saturday, Feb 22, 2014 at 23:57
I have a 2006 Navara ST-X with 2" Ironman lift and 2" body lift, also have rear air bags fitted. I'm happy with the ride the Ironman
suspension gives,the only thing is that the front has sagged over time.I have just fitted 25mm front strut spacers and extended ball joints to regain a level ride. That is the only downfall that I know of with the Ironman brand.
527040
Follow Up By: R&M (WA) - Sunday, Mar 16, 2014 at 10:52
Hi Scrubrat6 can you tell me wherre you got the extended ball joints from, I have a 2" lift kit that looks like it is running out of adjustment on a 2012 d40?
810986
