Engel fridge/freezer temperature indicator
Submitted: Saturday, Feb 08, 2014 at 12:14
Old 55
The B symbol in the temp indicator came up on my 40 litre Engel fridge/freezer the other day so I changed the small round battery in the lid and put it back together and now the temp indicator stays on all the time. I must be getting old but I can't remember the temp being shown all the time. Checked the battery installation and it can only go in one way. Should the temp be displayed when the fridge is off??
Cheers Rod
Reply By: Shaker - Saturday, Feb 08, 2014 at 12:36
Yes, it is displayed all the time.
525983
Follow Up By: Old 55 - Saturday, Feb 08, 2014 at 13:33
Thanks for that, as I said I must be going senile because I couldn't remember it being on all the time.
808090
Reply By: Member - Stephen L (Clare SA) - Saturday, Feb 08, 2014 at 13:00
Hi Rod
There are two types of batteries that power the LCD temperature display. The first series used the LR44 which would only last around the 12 month mark.
Engel then went for the lithium CR2032 which now lasts
well in excess of 3 years....
mine lasted nearly 5 years, and to answer your question, the temperature is displayed all the time.
The only exception to this was the introduction of the MR45FG Gold 50th Anniversary model. The temperature display on them is powered either through the either the 240v or 12v, depending what power you are using and the did play is in red and only on when the power is plugged into the fridge. There is now a new 40 litre combo fridge that uses this new power system.
525985
Follow Up By: Old 55 - Saturday, Feb 08, 2014 at 13:36
Thanks Stephen
mine has the 2302 and the battery has just seen it's 6th year without a change. I was positive that the temp went out when turned off but I must have been wrong
808091
Follow Up By: Member - Phil G (SA) - Saturday, Feb 08, 2014 at 14:10
Old55,
My temp goes blank when the fridge is turned off too, so you're not going mad!
It's a 2009 engel (MT45F-G4-S) and has the CR2032 battery - sticker under the lid says expected life 2 years -
mine's on the original too.
Stephen, there must have been a different variant around 2008/9
phil
808092
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Feb 08, 2014 at 14:24
Hi Phil
I have a 2006 model and like every new unit that we have in the
shop, the temperature display is on 24/7 , except the new models.
I can not see why it is going off........faulty battery???
The running of the fridge has nothing to do with powering the temperature control unit, so very strange. I know that in time, all model Engels will be going over to the new powered temperature control.
808095
Follow Up By: Member - Phil G (SA) - Saturday, Feb 08, 2014 at 16:37
Curiosity got the better of me and we have an answer!
I just removed the CR2032 battery and it was reading 0.35V - very flat. Put a new one in (3.25V) and it is now reading the temp all the time!
So as the battery goes flat, it must somehow get a trickle of power from somewhere to keep the temp gauge going when the fridge is turned on.
808101
Follow Up By: TrevorDavid - Saturday, Feb 08, 2014 at 16:38
My goes blank as
well when the fridge is off. Original battery, Fridge is 6 + years old ??. Has done this from day one
TDB
808102
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Feb 08, 2014 at 20:33
Hi Trevor
The internal temperature display is designed to be on all the time ans i would suggest that you purchase a new battery, as it sounds like the same problem that Phil had above.
808118
Follow Up By: TrevorDavid - Wednesday, Feb 12, 2014 at 20:52
Thanks Stephen.
Yes I agree.
808498
Reply By: Old 55 - Saturday, Feb 08, 2014 at 17:33
Well that's more and more confusing but
mine did the same new battery and it is on all the time. Maybe there is hope for me too. Gee if I put a battery up my A..e would I stay on all the time too. Thanks for the replies Guys
Rod
525997
Follow Up By: Ross M - Sunday, Feb 09, 2014 at 00:40
Rod
It is only for the fridge that "B" means the B is buggered.
808145
