Saturday, Feb 08, 2014 at 21:08
Splits, the differences between the modern dual cabs and vehicles that people consider to be the best tow vehicles are now not as great as you would imagine.
I have the new PX Ford
Ranger Dual Cab and have previously had a TD 100 series landcruiser for towing. The
Ranger honestly does the job easier than the Cruiser and the longer wheelbase (by 370mm) is more stable in adverse conditions and more than offsets the slight reduction in track width which is only about 60mm narrower than the cruiser.
Also if both vehicles are fully loaded to capacity, there is only a 60kg variation in weight.
The specs below are from the manufacturers websites.
Specs:
Ranger vs Landcruiser
Power: 147kw vs 151kw
Torque: 470nm vs 430nm
Length: 5331mm vs 4890mm
Wheelbase: 3220mm vs 2850mm
Track Front: 1560mm vs 1620mm
Track Rear: 1560mm vs 1615mm
Kerb Weight: 2177kg vs 2510kg
Gross Vehicle Mass: 3200kg vs 3260kg
Towing Capacity: 3500kg vs 3500kg
Payload: 1023kg vs 750kg
I too have made the same statements you have made in relation to heavy towing and modern vehicles. I still have 2 x f100 4x4's from the old school days of towing......but these new breeds of dual cabs are much larger, heavier, more powerful and economical and pretty hard to pass up as being very capable tow vehicles.
BW
808123
