Truma hws keeps tripping circuit breaker
Submitted: Thursday, Jan 30, 2014 at 14:09
ThreadID: 106011 Views:2205 Replies:3 FollowUps:8
Truma hws keeps tripping circuit breaker, any ideas
Reply By: Racey - Thursday, Jan 30, 2014 at 14:28
First suspect would be the element. Suggest you take it to a RV repairer.
AnswerID: 525385
Reply By: Notso - Thursday, Jan 30, 2014 at 14:42
Second that, my last van had same issue also several others in the van club. The 240 volt element leaks and throws out the CBD. That's not the Central Business District but the Core Balance Device!
AnswerID: 525387
Follow Up By: Ross M - Thursday, Jan 30, 2014 at 15:46
No. 3
That happens on many heater elements and the leak to earth does the CBD, spa heaters the same and house units too.
Seems many elements aren't super quality and have a relatively short life in that regard. The heater still works but it can't because of the inbuilt safety system.
That might be why some call them "Trauma".
FollowupID: 807355
Follow Up By: Allan B (Member, SunCoast) - Thursday, Jan 30, 2014 at 15:59
Oh come on guys. You will start up another "Pedantic" argument by using the term "CBD".
Everyone knows it as an "RCD" or Safety Switch.
And please don't start lecturing me on the construction or history of the device...... I already know.
FollowupID: 807357
Follow Up By: Slow one - Thursday, Jan 30, 2014 at 16:37
Allan,
they leak more int the CBD (central business district) than they do in an RCD ( regional business district)
Now is an earth leakage trip or a active neutral fault. Ha. Ha.
FollowupID: 807359
Follow Up By: Allan B (Member, SunCoast) - Thursday, Jan 30, 2014 at 17:24
FollowupID: 807361
Follow Up By: Notso - Thursday, Jan 30, 2014 at 17:35
Ah well, it's not often that I try to crack a joke!
FollowupID: 807364
Reply By: racinrob - Thursday, Jan 30, 2014 at 18:38
You have of course removed the exterior cover ? Something I sometimes forget and it won't light with the cover on.
Rob.
AnswerID: 525415
Follow Up By: Leef - Thursday, Jan 30, 2014 at 20:36
I'm not trying to light -gas - simply flicking the switch and it trips the circuit braker
FollowupID: 807371
Follow Up By: oldtrack123 - Thursday, Jan 30, 2014 at 23:30
HI
If it is tripping the 240V circuit overload breaker OR the RCD ,It realy is a job for an electrician !!!
Which ever it is you have a 240V fault .
PeterQ
FollowupID: 807380
Follow Up By: Leef - Friday, Jan 31, 2014 at 09:39
Thanks everyone for your advice. Electrician coming up.
FollowupID: 807388
