Saturday, Jan 18, 2014 at 23:29
The first thing you should do.....as sort of mentioned above...is get a load V pressure table for the tyres you are running....then weigh the thing axle by axle and apply the appropriate tyre pressures.
Toyota utes carry more or less the whole payload on the rear axle, you need to vary the tyre pressure to suit the load carried.
when I picked up my 2wd hilux from the used car dealer, the tyres where pumped up to 50PSI all round.... unladen it rode like a dray.....inflating to recommended pressures...down arround 28PSI all round unladen made a big difference.....fully loaded arround 60psi is required in the rears, but the fronts remain the same.
As people have mentioned,
The toyota shockies are not real flash even when they are in good nick, and they don't last long.
Again because the utes carry the whole payload on the rear axle, unladen
the springs are very stiff......this give the shockies a hard time.....the
suspension deflects over bumps and there is a tendancy to rebound fast and hard.
replacing the shockies in both my 2wd and 4wd made a huge difference....especially unladen.
Toyotoa utes need good shockies and are very hard on shockies.
The other thing is weight.
All these toyota utes ride a hell of a lot better with some weight in them....both in the tray and in the cab.
One reason lots of cockies run fairly heavy steel trays is because they are heavier and make the utes ride better unladen.
100Kg in the back can make all the difference..I recon 200Kg is good.
I noticed that both my utes ride a hell of a lot better with a pasenger in the cab....the weight gives the cab rubber
suspension something to work on.
I have moved a couple of heavy items into the cab....my drag chains and pully blocks and a couple of other things sit behind or under the seats...this extra 20 or 30 odd KG weight makes a difference especially when traveling alone.
I understand the toyota factory springs are not the cleveerest......no doubt a better set of aftermarket springs woul help......but try the other things first.
BTW.....whatever you tray post us back and let us know how it went.
524730
