Utrackme Beacon 2
Submitted: Wednesday, Jan 15, 2014 at 10:09
Member - Foot
Anyone out there know how to enter in more "points" in the tracking, when I
check the EO Tracking map it has only 4 or 5 "points" over 25km of travel.
I have tried numerous settings which don't seem to work as
well as other members tracking I have seen using iphones.
Reply By: ExplorOz - David & Michelle - Wednesday, Jan 15, 2014 at 18:53
Foot,
I assume you have the
Beacon Settings option installed?
Are you adjusting the right value - if you are on power in your car you need to adjust the
On External Power - WWAN - timings try sleep time 30 sec and trigger 1 min. This will look for a positional move ever 30 secs and will force a position update every minute. This may be too many but this is the area to play around in.
David
524571
Follow Up By: Member - Foot - Thursday, Jan 16, 2014 at 10:27
Thanks David, yeah played around with this before but I haven't had it powered up through anything else except battery at this stage as I have been mainly on a motorbike and testing it going back and
forth to work, I will set it up from what you recommend for both battery and power and see how it runs. What settings did you have for trigger sensitivity?
Thanks again.
806308
Follow Up By: Member - Foot - Thursday, Jan 16, 2014 at 16:44
David g'day, thanks for the advice it works!
806333
Follow Up By: ExplorOz - David & Michelle - Thursday, Jan 16, 2014 at 17:03
Excellent and to answer your question - Normal for the trigger sensitivity.
David
806339
