led lights on a jayco sterling 2009 model are they 24 volt compatible
Submitted: Sunday, Jan 05, 2014 at 18:19
ThreadID: 105699 Views:3604 Replies:4 FollowUps:7
I want to tow our 2009 jayco sterling van with our truck but the truck runs a 24 voolt system does anyone know wether the led lights are 24 volt /12 volt or re they just 12 volt
Reply By: Ross M - Sunday, Jan 05, 2014 at 18:35
G'day Scott
Probably not something most have looked at or even considered.
If you undo/ flick out the light unit on the van you will see in the back a white printing which may say 12/24v. If it has that, then the internal circuitry detects when the voltage goes over the normal slightly higher than 14.5to 15v and it then dulls all lights which are on and they gradually get brighter as the voltage rises to the level used in a 24v system.
If you can't get to the lights then switch on the parkers and note the brightness.
Remove plug from towbar and use a normal plain old battery charger connected across pin 3 and pin 7. Only the correct way will light the lights though as they are LED ie one way electrical valves.
Since a plain battery charger gives out about 16 to 17v dc it will light the lights but they will go into the dull phase. If they go dull it is a 24v compatible LED lamp. In not 24v compatible the LEDS will be brighter with no dulling observed.
Ross M
AnswerID: 523940
Follow Up By: scott s1 - Sunday, Jan 05, 2014 at 18:40
Thanks a lot Ross
I will give it a go.
Cheers Scott
FollowupID: 805539
Follow Up By: sub - Sunday, Jan 05, 2014 at 20:30
Hi Scott
I have Jayco Dove camper and am replacing the side-marker lights with led Narva and the packet says 9-33 v only replacing the old ones as they have gone brittle with age.
hope this helps
Dean
FollowupID: 805542
Reply By: Garry E1 - Sunday, Jan 05, 2014 at 23:41
As far as I know all LED lights are 12/24v compatible. If you are not sure check the Narva or Hella site online.
Gazz
AnswerID: 523948
Follow Up By: Ross M - Monday, Jan 06, 2014 at 09:32
All LEDs may be 12/24 but if the OE aren't, then the info won't necessarily be true for him.
Jayco in their cheap production wisdom, may have used a special 12v only bought for their purpose.
Never assume, Best to check first and the Narva site can't physically do that.
FollowupID: 805550
Follow Up By: scott s1 - Monday, Jan 06, 2014 at 09:57
Thanks a lot to everyone that has replied
I plugged it into truck last night and all worked well but I would say that there was a remarkable difference in the brightness on the truck compared to the car (a lot brighter on the truck) would this lead you to believe that they were 24 volt compatible
Cheers Scott
FollowupID: 805551
Reply By: vango - Monday, Jan 06, 2014 at 11:05
There are other things to consider as well such as running the 12v fridge on 24v while travelling also the 12v charging system while travelling.
AnswerID: 523967
Follow Up By: scott s1 - Monday, Jan 06, 2014 at 12:06
Thanks Phil
I had to wire the plug up for the truck as it didn't have a trailer plug and I have only wired it in for the blinkers tail lights reverse and brake lights I didn't run a power line off the truck so hoping that wont affect anything in van as it has its own battery system which trickle charges when plugged into power.
but in saying that I will definitely look into that.
Cheers scott
FollowupID: 805561
Reply By: tonysmc - Tuesday, Jan 07, 2014 at 13:46
Hi Scott,
On a separate matter, you may be interested to know that you can run 12 volts from your 24 volt truck to the caravan if you want to have internal lights etc. you just need to run a positive and negative wire from only one of the batteries. Use the second battery that is connected to the earth. You can easily test the voltage with a multimeter and truck running before you try it, if your unsure if it’s true.
Tony
AnswerID: 524037
Follow Up By: scott s1 - Wednesday, Jan 08, 2014 at 07:33
Thanks Tony
I ended up buying a redarc trailer light power reducer, for the lights.
I willl give that a go.
Cheers Scott
FollowupID: 805656
Follow Up By: scott s1 - Wednesday, Jan 08, 2014 at 07:35
And the lights were only 12 volt
FollowupID: 805657
