Keeping suction cups from falling off ??
Submitted: Tuesday, Dec 10, 2013 at 15:47
ThreadID: 105443 Views:3188 Replies:11 FollowUps:6
Hi all
I have our GPS device attached to the windscreen with a 70mm suction cup. All works well for a few days then in the heat- it falls off. Have cleaned the glass with metho and made sure the suction cup is clean, but still falls off !! Any ideas.
Wombat
Reply By: RickC - Tuesday, Dec 10, 2013 at 15:59
Hi wombat 100 I use to sell large farming GPS units I found Loctite made a product called
silicone grease I found a small wipe of this over a clean suction cup really worked well hope
this was help full.
AnswerID: 522854
Follow Up By: wombat100 - Tuesday, Dec 10, 2013 at 16:10
Thanks mate- I have some of that out in the shed !!!
Anyone else with suggestions???
FollowupID: 804031
Follow Up By: Member - Frank P (NSW) - Tuesday, Dec 10, 2013 at 16:24
A smear of Glycerine from the medicine chest?
FollowupID: 804033
Reply By: Bludge - Tuesday, Dec 10, 2013 at 16:09
try washing up liquid, works for me.
AnswerID: 522856
I can see the sense in that- it wouldn't 'evaporate'...Thanks
FollowupID: 804032
Follow Up By: Shaker - Tuesday, Dec 10, 2013 at 19:59
The only way moisture could evaporate would be if the suction cup wasn't sealing correctly.
FollowupID: 804045
Reply By: Member - LeighW - Tuesday, Dec 10, 2013 at 16:28
Maybe Vaseline but I haven't tried it.
AnswerID: 522857
Reply By: SDG - Tuesday, Dec 10, 2013 at 16:43
Mine has recently started doing the same thing, except it only last an hour or so. I'm about to get some silastic and mount the thing permanetly.
AnswerID: 522859
Reply By: Sand Man (SA) - Tuesday, Dec 10, 2013 at 18:47
I use a bit of saliva:-)
Bill
AnswerID: 522865
Reply By: Member - Ron O (VIC) - Tuesday, Dec 10, 2013 at 20:12
Hi wombat check to make sure there is no split in in the suction cup mine was doing the same turned it had a small split
AnswerID: 522868
Reply By: Batt's - Tuesday, Dec 10, 2013 at 22:17
This probably won't help unless you have an old car like my GQ but when mine keeped falling down I screwed the mounting bracket to the front drivers side door pillar so it's sits in the perfect spot for me. It might be a bit rough for most but on the plus side guaranteed not to fall of on the roughest roads.
AnswerID: 522871
Reply By: Brian 01 - Wednesday, Dec 11, 2013 at 06:47
A few small dobs of supaglue gel will do it on some cups but won't adhere to others.
Put the glue on the cup, in from the edge so that it only makes contact with the glass once the cup is pushed down, this way it won't be smeared over the glass as you compress the cup.
Hold it in position for 30 seconds and it won't fall off again.
It's quite easy to remove if need be with a razor/box cutter blade slid between the two surfaces.
AnswerID: 522874
Reply By: Member - Jack - Wednesday, Dec 11, 2013 at 09:15
A friend of mine solved this problem by smearing the inside of the cap with egg white. Might also provide a source of food in an emergency, perhaps ... : )
I haven't tried it myself, so it is a 'hand-me-down' idea.
Jack
AnswerID: 522879
Reply By: Member - Matt M - Wednesday, Dec 11, 2013 at 16:15
I've used KY or similar before and works well. Water based, so washes off easily enough when done. Egg white may be good food in an emergency, KY good for other emergencies.
Matt.
AnswerID: 522896
Follow Up By: Member - Jack - Wednesday, Dec 11, 2013 at 19:39
You obviously have much better emergencies than I do.
Jack
FollowupID: 804111
Follow Up By: Member - Scott M (NSW) - Wednesday, Dec 11, 2013 at 20:02
What's seen can't be unseen ...........
FollowupID: 804114
Reply By: Bravo Man - Wednesday, Dec 11, 2013 at 16:43
My Garmin mount kept falling off every day. $5 for a new one on Ebay,hasn't fallen off since.
AnswerID: 522900
