Caravan warranty
Submitted: Thursday, Nov 28, 2013 at 05:55
ThreadID: 105297 Views:4540 Replies:9 FollowUps:16
As experienced owners of 8 caravans, some new and some second hand , it amazes me that you can spend up to $100,000 on a caravan and you only get 1 years warranty. You can go and buy the cheapest new car and you will get 3 years warranty. It seems to me that caravan manufacturers are purposefully dragging their feet on this issue. Surely if you pay large amounts of money for a new caravan you should get a longer warranty. There must be lots of other caravan ears that feel the same as we do. What can be done about it?
Reply By: bluefella - Thursday, Nov 28, 2013 at 06:33
I'd try the bluff, give me another years warranty or I'll buy a second hand one same make same specs for a lot less.?????
AnswerID: 522225
Follow Up By: bluefella - Thursday, Nov 28, 2013 at 06:45
Should add if they don't agree leave your phone number and leave, give em' time to think about it. you can go back and take the original deal.
FollowupID: 803196
Reply By: Racey - Thursday, Nov 28, 2013 at 08:47
I believe it depends on what you buy and from whom. We have a Evernew van; four years down the track we had water seeping from the ensuite. After checking the obvious I concluded we had a broken pipe in the wall. Contacted Evernew and spoke to owner, Bruce Bailey after a brief discussion, I was to take it back to the factory.
The short story is there were no broken pipes, just a crack in the cap of toilet flush tank overflow. After spending 4 hrs cutting holes in the cupboard and inspecting pipes etc, I was expecting to pay a few hundred $ for their time. After all the problem was not warranty. Bruce was helping me hook up the van and I asked " what do I owe you Bruce?" The response was a slap on the shoulder "we're just pleased you are happy with your van". I have spoken to other Evernew owners who cite similar stories.
Racey
AnswerID: 522231
Follow Up By: K&FT - Thursday, Nov 28, 2013 at 09:43
and I would call that "customer service". their best advertising comes from happy customers and what it cost him to do what he did for you would be a lot less than the cost of advertising to have the same effect.
frank
FollowupID: 803202
Follow Up By: Ross M - Thursday, Nov 28, 2013 at 13:02
It sounds like the design is poor and to have to cut holes just to be able to inspect where a leak may be happening is downright stupid.
Now you have a Swiss cheese van and ready made mouse access throughout.
I must remember that," Have/Use battery drill and hole saw as a diagnostic tool.
It is a pity they didn't check simple things first to save the wear and tear on the hole saw.
FollowupID: 803214
Follow Up By: Shaker - Thursday, Nov 28, 2013 at 13:27
Using your rationale, maybe they should make vans with no internal lining, then they could access wiring & plumbing!
FollowupID: 803219
Follow Up By: Ron N - Thursday, Nov 28, 2013 at 13:45
Ross, show me the caravan, vehicle, house, item of equipment, etc, that has 100% of its wiring and plumbing instantly and readily accessible - and I'll wager you can't produce it.
I've spent a sizeable portion of my life trying to access wiring and plumbing that is buried deep in the construction or manufacture, with no thought given to future access for problems.
Years ago, I saw blokes attacking a service station concrete forecourt with jackhammers, across its entire width, because some smart cookie buried the bowser wiring in the concrete - and the wiring developed a fault that couldn't be accessed.
The only cure at that time was to jackhammer up a huge length of forecourt and replace all the wiring that had been concreted into it.
Concrete saws have replaced jackhammers today, but the concrete saws still get produced on regular occasions when someone has concreted over a vital piece of wiring or plumbing that has failed.
Ever thought about how you'd access the PVC piping for the plumbing that goes through and under your concrete house pad?? It's the stuff of nightmares.
I've seen a 4 week old house fill up completely with 600mm depth of water because of a plumbing leak inside a double brick cavity wall.
The house was completed, the family moved in 2 weeks before Christmas - they went away for a fortnight over Christmas/New Year, locking the house up tight as a drum.
Meantimes, an untested join in copper pipe that was leaking inside the cavity wall, filled the entire house to 600mm deep with water. The damage was horrendous as you could imagine, and the owners were distraught.
Too many problems are caused by inadequate checks of workmanship, and the rest are caused by poor design.
Cheers, Ron.
FollowupID: 803221
Reply By: The Landy - Thursday, Nov 28, 2013 at 09:46
Customer advocacy, no amount of money can ever buy it – you can only ever earn it…
Great story…
AnswerID: 522233
Follow Up By: The Landy - Thursday, Nov 28, 2013 at 09:47
Whoops, was in response to the comment above...
FollowupID: 803203
Reply By: Member - John and Lynne - Thursday, Nov 28, 2013 at 09:57
The new consumer legislation (Gillard Government) clearly states that a manufacturer cannot just walk away from a warranty obligation that a "reasonable person" would expect. That is, according to the amount of money spent and the expected longevity of the product, a manufacturer is liable for faults in the product. The product must be repaired or replaced. I recently won a battle with a manufacturer of a product costing about $300 which failed to work satisfactorily after a few months. They tried to claim an exclusion clause in their warranty meant that I had to pay the costs of repairs or adjustments. After I quoted the new legislation in detail, showing that a warranty cannot be removed by any waiver or exclusion clause a purchaser may have signed, the bill for repairs was withdrawn. Manufacturers are expected to provide products that are "fit for purpose" with a longevity expected by a "reasonable person".
A consumer friendly summary of this legislation is available on line from the Dept of Consumer affairs. I am sure it would apply to caravan manufacturers who try to pretend they have no obligation to make a van that is "fit for purpose" for more than a year!
AnswerID: 522234
Follow Up By: Neil & Pauline - Thursday, Nov 28, 2013 at 11:32
To rely on the "Gillard" consumer legislation is flawed when it come to the more major investments in our life. The limit of protection is $100,000 so motor homes (and bricks & motor houses) are not covered. The civil court is the only way to get settlement if you are prepared to spend a couple of million dollars. I have been 8 years trying to get my day in court and in hindsight should have just built another house.
Neil
FollowupID: 803206
Reply By: Member - Tony H (touring oz) - Thursday, Nov 28, 2013 at 10:00
Very similar story to above with my Kedron, 6 yers old now, developed a leak in the roof mind you AFTER I had hit the roof with a high pressure water cleaner.... Spoke to Kedron .......... full roof reseal ..........NO charge .........great people to deal with ....very happy customer
AnswerID: 522235
Follow Up By: Con_Qld - Thursday, Nov 28, 2013 at 22:58
Tony, Yes I hear the Kedron people are really good with their warranty.
I have a Crusader Manhattan but after many window leaks and 4 years later, they told me sorry out of warranty. I know what I will be buying in future and what I would be recommending.
Cheers...
FollowupID: 803294
Reply By: pop2jocem - Thursday, Nov 28, 2013 at 13:05
Having been in business for more years than I care to remember,m the best "salesman" sorry "salesperson" is the satisfied customer. The most effective way to handicap your business is to have multiple dissatisfied customers. They will tell anyone who will stand around long enough what a thorough bastard you are embellished to the nth degree.
It takes a while to build up a good reputation, very little time to destroy it.
Pop
AnswerID: 522251
Follow Up By: Ron N - Thursday, Nov 28, 2013 at 13:48
Pop, never were truer words spoken. It's amazing how many businesses fail to understand that fact.
Cheers, Ron.
FollowupID: 803222
Follow Up By: get outmore - Thursday, Nov 28, 2013 at 17:00
whilst this is true theres no pleasing some people.
while one person is happy the fault is fixed the next guy might get on the forums and badmouth the heck out of them because in thier mind the fault shouldnt have happened in the first place. These people will tell alot more about how bad the place was than the guy who was happy with the service sad but true.
Restaurant and hotel sites are a great example.
I recently went overseas so looked at quite a few of them
EVERY place had reviews that ranged from very happy to total crap.
Did these people go to the same place?
sometimes it could be written off with the odd bad experience at a good place
I used to read alot of the reviews - you get a feel for what the truth is. If someone spent alot of time writing a very long and detailed review about every single speck of dust found on top of the cupboards I would write that off as a proffesional whinger.
However if someone had just written a few lines that they were after a place for the night andfd that was it and while they didnt expect much except a clean bed and working TV and they couldnt even get that - Id take notice.
also by reading all the reviews I felt I got a good picture of the place and ended up getting no dud s
FollowupID: 803249
Follow Up By: rocco2010 - Thursday, Nov 28, 2013 at 20:16
Gidday Get out more
Sites like tripadvisor are notorious for rivals giving hotels and restaurants bad reviews. Last year I was looking for a hotel in Paris, location was important, budget price was attractive. Found a place which had middling to so-so reviews. The standout was the guy who claimed he had been eaten alive by the worst bed bugs he had ever seen. Funny, No one else mentioned bed bugs so I guessed he was the troll. I stayed there, it was OK for the price and no bed bugs.
FollowupID: 803271
Follow Up By: get outmore - Thursday, Nov 28, 2013 at 20:33
best one I found was "rustic cabins" at a place called macks in near yellowstone
had alot of bad reviews saying that rustic didnt begin to describe how basic , dusty, filled with bugs etc this place was - apparantly didnt even have internet or phone reception
we needed a place (was peak holiday season)
and ended up in a great cabin with seperate bedrooms (great as we were 2 blokes)
fullsized fridge all the cooking gear clean bathroom, grassed front yard with outside seating and table , near a pituresque river, and ended up listening to the ashes over internet radio on my phone
---- just goes to show
FollowupID: 803275
Follow Up By: graham B9 - Thursday, Nov 28, 2013 at 22:14
Get out more I know what you mean. A week ago there was a hail storm on the sunshine coast in Queensland. Hail the side of passionfruit and almost ever caravan in the park was damaged. Awnings shredded and hatches smashed.
I was talking to the park manager and asked "how many people blamed you for the storm". The answer was 2 people.
FollowupID: 803288
Reply By: AlanTH - Thursday, Nov 28, 2013 at 15:31
As others have said the 12 month warranty isn't the full extent of your cover as consumer protection laws go way beyond that.
We bought a new Goldstream 2 years ago and had problems right off with tyres wearing rapidly (retailer George Day in WA said wheel alignment but did nothing to check if that was so), curtain lining full of holes said by Goldstream to be moth eaten although holes were in straight lines), curtains eventually replaced after George Days service girls chased them up (thnx to Jodie & Tamara) and sent heaps of pics to them. Plus pelmets and head protector over the door fell off, drawers opened when closed and locked.
We received new curtains tightly screwed up into a bundle and taped and wrapped in plastic. Nothing like good customer service Shaun.
I went to WAs consumer affairs people and they negotiated a new tyre to replace the badly worn one and new shocks.
That failed to fix the problem and the tyre fitter checked all 3 wheels and found 2 were nearly 12 mm out of true, the third was only just acceptable. The original tyre fitter should have noticed this but I doubt Goldstream would cared anyway from their attitude.
The retailer immediately said we were out of warranty, van hadn't been serviced in accordance with their instructions, van had been mis-used, in fact anything to get out of doing anything.
At no time did Goldstream even bother answering emails about our problems.
So off we went to the small claims court as consumer affairs said this would be the best way to get to the manufacturer, a notice of the action was served on them (GDay)and Goldstream paid up immediately for the amount we claimed.
Steve Day the retailers GM advised he wouldn't have settled but his attitude along with his fathers (original owner of the company, now deceased) is always the customer is wrong if they can't fix it with a tube of silicone.
This the second rv from Goldstream, third from George Day and definitely the last from both of them.
Do not accept what they say if they won't admit any liability, there's help out there even if it takes a bit of time to get what you want.
AlanH.
PS. It appears from our latest trip (1000klm) that our problems may have all stemmed from the badly bent and unbalanced wheels as we suspected, as the tyre wear seems to have gone and nothing dropped off.:-)
Further, when the maker says that everything is to "industry standard" don't accept it, there's no standards, it's whatever they can get away with.
AnswerID: 522260
Follow Up By: Ron N - Thursday, Nov 28, 2013 at 16:09
Alan - Do you know if the wheels and tyres were new or used? It's entirely possible some manufacturers are using wheels purchased from wreckers, from wrecked vehicles.
Such wheels are often buckled due to rollover or impact forces, and unless they're checked to see if they meet runout specs, they will then pose major problems with imbalance and excessive tyre wear.
I'd expect any caravan/trailer manufacturer who uses secondhand wheels and tyres from wrecks would never bother doing runout or damage checks on them. The same goes for import tyres and wheels.
Cheers, Ron.
FollowupID: 803244
Reply By: riderau - Thursday, Nov 28, 2013 at 16:44
Leone C.
You say that you have had several vans both new and 2nd hand. You also mention you have had warranty of 12 months. I have purchased two second hand vans and have been told there is no warranty on second hand vans. Guess living in Cairns has its draw backs in more ways than one.
rider au
AnswerID: 522268
Follow Up By: Leone C - Friday, Nov 29, 2013 at 08:11
No we had no warranty what so ever on the second hand vans, it was only the two new vans we purchased that had 12 months warranty . Ridiculous for the amount of money you pay.
FollowupID: 803306
Reply By: Erad - Friday, Nov 29, 2013 at 10:04
We have had 2 new caravans over the years. Both had badly misaligned wheels - 11 mm toe-out on the first and 10 mm on the second, so things are getting better. Both had solid axles, so you would expect zero toe-in or toe-out. The first van was a Viscount, the second Jayco.
Now I have started on the Jayco... Their service was appalling. I have had 2 power supplies fail - ultimately bought a different system and installed it myself - 10 yrs down the track it is still going. The overhead cupboards fell apart in 4 separate places. I had to screw them back on the road. The roof sealing was suspect. But the worst was the axles.
After 18 months, I had about 18000 km up and noted the inside edge of the tread was worn to the steel belt. Jayco warranty is 2 yrs or 20000 km, so I rang Jayco. "No sir - the warranty for the wheels is by AL-CO and it is only 12 months". I bought a new tyre and fitted the brand new spare and limped home. I checked the alignment and found 10 mm toe-out. Because I had to be in Sydney for a while with the van, I removed the axle and turned it around to equalise the tyre wear (I also had to re-set the brakes because they were then back to front). Whilst doing the removal, I noted that the axle was offset from the chassis. About 20 mm to the left. The chassis rail had been dented by the U bolt, seriously weakening the chassis. I took photos and composed a letter to Jayco, informing them politley that they had stuffed up in their manufacture. What were they going to do about it?
They studiously ignored my letter. I sent 3 faxes to them, asking for a reply. I made numerous phonecalls, and the service manager was not available, but would ring back. Finally, I had to go to Melbourne on another matter, so I removed the axle again and loaded it into my trailer. I went to the Jayco factory and the guard at the gate told me to park over near the showroom door. I did this - the trailer was parked such that anyone who wanted to get in or out of the showroom had to walk through my trailer! I then asked to see the service manager. He was in his office, and when I told him my problem, his reply was that he wished he had been informed about it before I went this far! A mushroom cloud then formed over my head. I told him of the letter, the faxes, the phone messages. He looked through his in-tray (piled up about 30 cm high) and then he found all but one of the phone messages and all of the other correspondence. He then bum shuffled the issue onto AL-KO, but I insisted that the fault was with Jayco because they had fitted the axle way off centre. Eventually he agreed. He said that Jayco would repair the chassis by welding a steel plate on the side of the chassis (the bottom of the chassis rail was bent - not the sides). He sent the axle to AL-KO to be straightened.
To their credit, AL-KO were wonderful. They 'straightened' the axle, but it still had about 7 mm toe-in. They said that some toe-in was necessary on a solid axle to gice it stability. I cannot see that myself, but I accepted it. They freighted it back to my home, and also reimbursed me for the new tyre I bought. Short story made long, I wore out the next set of tyres in about 40000 km, and was well on the way to wearing out the next set when I contacted AL-KO from Tom Price, asking them what the toe-in should be. When I got home, there was a letter from them asking me to send the axle to them at their expense and they would make me a new axle, which they did. By this time, the van had about 130000 km on it and it was 11 years old. AL-Ko's service was AI.
The tyres now are wearing evenly (despite still having about 4 mm toe-in). An aftertought - one of the hubs collapsed about 100 km from home. I felt a sudden increase in drag, and thought I had a flat tyre. I checked and all looked OK, so I drove home with no more problems - the extra drag had gone. Next morning I decided to repack the wheel bearings before I put the van away, and jacked up the wheel, only to find excessive end float on the bearings. I checked the castle nut and all was good there, so checking the bearing, I found the hub had partially collapsed. I phoned the service manager of AL-KO, asking him for details as to where I could get a new hub. He asked me to send him the old one (and the other as well) so they could examine it. He sent me 2 new hubs (free of charge). This was probably after 135000km. They examined the hub and found a small defect. Now that is what I call GOOD customer service (especially compared to Jayco).
AnswerID: 522307
Follow Up By: Axle - Saturday, Nov 30, 2013 at 14:49
G/day Erad, which model Jayco out of interest,B
inlaw just purchased a 05 25ft Heritage,..Hope it doesn't fall apart its their house for a while ..lol.
Cheers Axle.
FollowupID: 803399
