Friday, Nov 22, 2013 at 14:45
Hi Mike and Barry
Just wet the stuff and peel it off.......
well you have to actually scratch it at a leading edge. Even if you goes through a thunder storm, it does not come off.
On one of my trips returning
home after being bush, we were in some very heavy rain for over 2 hours. I was hoping that it was going to be that wet, it was going to blow off while driving along......no such luck, yes it went a real milky colour, but stayed in place.
Mike I have found from past mistakes that the most important coat is the first. Do not make it thin, but thick, then build the following coats up. Make sure that the previous coat is quite dry before applying the next.
One point that I did not mention, it it must be cured for at least 4 days before putting it to work.
Those that have never used the gear before will be the sceptics, while those like me that know just how great the product will never go bush with using it.
802773
