HF unit installation question
Submitted: Wednesday, Oct 16, 2013 at 10:13
pepper2
After replacing the patrol with a dual cab ute with canopy,i am finding it difficult to reinstall a barrett 950 hf on the dual cab. Problem is where to locate the antennae,dont want to fit on bull bar,cant use the spare wheel bracket as on the patrol,wondering if anyone has an idea,any advice appreciated ,thankyou.
Reply By: racinrob - Wednesday, Oct 16, 2013 at 12:12
No easy solution pepper2, members of the HF club I'm in resort to a custom made post (aluminium) fixed to the chassis rail behind the cab and mount their Autotune on top of that.
Have you seen the new Codan Envoy super compact aerial ? Small enough to mount behind your grill, worth a look.
Rob VKE236 6678
519788
Follow Up By: racinrob - Wednesday, Oct 16, 2013 at 12:14
Ahem, that should be VKE237.
Rob
800048
Reply By: Bob Y. - Qld - Wednesday, Oct 16, 2013 at 12:17
Pepper,
It's a long time since I've had to fit an HF antennae, when we would weld a bracket on the bull bar and bolt a spring base and multi-whip in place.
Have seen, on a couple of utes, the self-tune bases mounted on the front of the head board, on either side of the cab. Would depend how wide your tray was, and how close it is to the cab, but would provide an out of the way position, with the whip up above the cab/canopy roof.
Might just be susceptible to over hanging branches though?
Bob.
519789
Reply By: allein m - Wednesday, Oct 16, 2013 at 14:02
Ok few months ago I saw a SA police car parked in the main street of
Broken hill common thing they often come up shopping
any way he had toyota hilux duel cab with the cage on the back he had the rear step tow bar type thing both ARB and TJM have them the
HF radio antenna was put onto that I have a picture some where if I find it I will post it
519798
Reply By: Robin Miller - Wednesday, Oct 16, 2013 at 14:37
HF Whip Bracket
Not knowing why you don't fit to Bullbar makes it harder Pepper , I don't like Bullbars but still felt need to have my Barrett 950 HF Whip visible while driving and so made an aluminium bracket back to my chassis rails.
Most of the time I just run a short 27mhz whip which is sufficent to moniter transmission and then put bigger whip on when I need to tranmiit.
This solves the most important problem because the top of the 27mhz whip is same as a shopping centre
parking barriers height and so if aerial doesn't hit I'm ok , great to stuff up those who like to put max height 2.0m on their signs.
519802
Reply By: Member - bungarra (WA) - Wednesday, Oct 16, 2013 at 14:50
Mine is not a dual cab but same principle applies...hopefully my rig photo may show how I located
mine........it is on a 20mm dia piece of pipe that I raise up (slides through a short length of 25mm)
This way the whole thingy is protected during travel and I simply raise it clear of the roof to use it..
Barrett told me that the whip AND the
grey plastic housing should all be clear of the cab and surrounding metal as the whole lot can contribute to poor signal in/out
I have seen a lot of rigs with the antennae not clear (like the Police vehicle photo but maybe the Codan is different?)
Previous to that I had
mine snug in and fixed and did have transmission / receive issues.......since making the telescopic pole it works a treat...........
It means that I have to be stationary to use if but with these modern computerised vehicles the HF can cause some funny glitches in the computer system...so I never use it with the engine running
519803
Follow Up By: Member - bungarra (WA) - Wednesday, Oct 16, 2013 at 14:54
just looked at my rig picture and that shows the original position...had major issues with signal transmission losses when operated there..........now it transports in that position, but it is mounted on a 20mm pipe that simply telescopes up as described in my post above....if you need the mark 2 picture let me know
800063
Reply By: MEMBER - Darian, SA - Wednesday, Oct 16, 2013 at 16:46
At risk of stating what you may already know.....Barrett have instructions in their 950 manual on the clearance you should have between any metalwork and the autotune - also, that the whip should be proud of the roof line as I recall, for optimal performance. I've had my 950 on two vehicles (neither a ute unfortunately), but following that installation guidance it has always worked very
519815
Reply By: pepper2 - Wednesday, Oct 16, 2013 at 18:44
thankyou for your replies,to clarify...
I have a barrett 950 auto tune antennae it is approx 10 cm in dia.
i only have about 3 cm between the metal cabin and the fiberglass canopy.
Rob can the codan envoy compact be fitted to the barrett ?
Robin didnt know the antennae you use,can i use it with my barrett ?
i do have a bullbar but would rather not use the bull bar because of the possibility of animal strike or similar destroying the antennae,and restricting vision.
Bob Y have a fiberglass canopy on a ute tub/no front head board.
Allein the ute tray has a drop down tailgate,unlike police vehicle in photo.
Was thinking of possibly mounting the antennae horizontally on bull bar on a hinge arrangement ,allowing it to be raised and whip aerial attached when hf required for use....what do you think ???
519821
Follow Up By: allein m - Thursday, Oct 17, 2013 at 10:58
sorry the hilux I did see had the drop down try and was set up in the same way just between the side of the car and the drop down try
I did wonder if it blocked the rear tail light
have a look at the arb rear step
800136
Reply By: allein m - Thursday, Oct 17, 2013 at 17:00
Today in
Broken Hill i saw a ford
ranger with a duel wheel carrier set up
I looked up this one i know it is expensive but I am sure you can find a cheaper option
this would be a legal option if the roo bar option is not legal
wheel carrier
I know you like the roo bar option I am only trying to help with what I see
the problem today is police are a lot harder and so many things that have been sold for your car may not be legal in some states as one person in a spare parts
shop said to me "we only sell the product it is up to you to make sure it is legal "
I understand your frustration
519865
Follow Up By: pepper2 - Friday, Oct 18, 2013 at 08:41
thankyou for your post,good idea.
800205
