Where is the fuel rail in a 3.0 l 2006 Nissan Patrol ST-S?!?!?!?!
Submitted: Friday, Sep 20, 2013 at 17:17
rustyhight
Hi all.
Looking for a little help please, I have been searching for the fuel rail in my 06 Nissan ST-S, injected auto inter cooled etc and can't find it... A little embarrassing...
Any help would be much appreciated.
Reply By: Tonyfish#58 - Friday, Sep 20, 2013 at 17:40
You would not be alone :-) Had a heck of a time finding it on my Rodeo to fit a chip.
Mine was down under the Intake near the starter motor. Should have all the fuel feeders connected to it :-)))
Best of luck - Regards Tony
518502
Reply By: Member - Bentaxle - Friday, Sep 20, 2013 at 18:36
Rusty, I had a 2006 GU3L motor until recently, it did not have a fuel rail, each cylinder had its own injector fed from injector pump. I think it was the 2007 that came out with a common rail injecter system.
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
518507
Follow Up By: olcoolone - Saturday, Sep 21, 2013 at 05:58
And if it is common rail NEVER disconnect the rail when the engine is running...... unless you want to lose fingers.
798399
Reply By: rustyhight - Saturday, Sep 21, 2013 at 12:57
Thanks for your help.
Could anyone tell me where to put the chip then? It's a "no limit tuning" one...
T
Cheers.
518530
Follow Up By: Member - Bentaxle - Sunday, Sep 22, 2013 at 21:43
Is it a 'plug-n-play' type? I have a Steinbeur chip on my Patrol and it plugs into the injector pump, all you do is unplug the existing wiring harness plug in the chip then plug the original harness into the chip.
798514
