Jayco Expander Outback water tanks
Submitted: Tuesday, Sep 17, 2013 at 19:22
Old Mal
Our Jayco Expander outback has twin
water tanks but only one ever seems to empty, the other
tank remains full. I have looked everywhere for a change over valve but can't find one and Jayco have not responded to my request for help on this. Does anyone know if there is a changeover
water valve on these caravans or do I have a blockage somewhere on the second
water tank system ?
Old Mal (frustrated !)
Reply By: Member - Toyocrusa (NSW) - Tuesday, Sep 17, 2013 at 20:40
Most Jayco's,
mine included, have a change over valve on the off side in front of the front wheel (dual axle) It has to be close to the inlet side of the tank/s so have a look in that area. Bob.
518319
Reply By: Member - Wayne B - Tuesday, Sep 17, 2013 at 21:41
Mines in the same spot
Discovery Outback
518323
Reply By: ed c1 - Tuesday, Sep 17, 2013 at 21:58
yep
mine is in the same spot on my sterling...
very hard to see the pointer though as it is all black ,, take a torch and take a good look .when you find it give it a dab of white paint so you can see it... on
mine with the pointer pointing up at floor of the van both tanks off,,pointing to rear ,rear tank pointing to front , front tank,,pointing to the ground both tanks on
its best not to travel with both tanks on,, as should one tank get ruptured you only loose
water from that tank
travel safe ed
518325
Follow Up By: member - mazcan - Wednesday, Sep 18, 2013 at 14:57
hi
using a white-out pen is the best thing for making white marks and you don't need a tin of paint or a brush
the white-out ink is hard-wearing and long lasting
just make sure you give the pen a good shake before use and wipe the nib after
for black marks use a permanent marker pen
798177
Reply By: glids - Wednesday, Sep 18, 2013 at 09:47
Just a safety/health warning...
If you have had
water in one
tank for some time, and not used it, refreshed it etc, I would strongly recommend draining that
tank and flushing with disinfectant.
There are numerous solutions available for disinfection, including bleach, Miltons and specialty liquids from caravan accessories
places - Google 'cleaning
water tank on caravan' or similar, or search this site or the caravan forums.
I use normal household bleach (White King etc) which should be 4% hypochlorite solution. I mix 150mL into my 60L
tank to give a 100 parts per million (ppm) solution in the
tank, and this is mixed through the
tank and pipework with my pump and left overnight. 100ppm of chlorine will kill most nasties in your
tank and pipework. If you want to use bleach, check the % chlorine (should be 4%), and adjust the amount you use according to the size of your
tank - ie 150mL into 60L
tank, 200mL into 80L
tank etc. You should be able to still 'smell' chlorine in the
water the next day when you drain the
tank. Flush the
tank out 2 or 3 times with clean
water before filling for use.
cheers,
glids
518351
Reply By: Old Mal - Wednesday, Sep 18, 2013 at 17:10
Thank you all for the advice - problem solved and second tank drained and flushed ready for the "
Bridgetown Blues Festival" in November
Old Mal (happy again)
518377
