Wednesday, Sep 11, 2013 at 14:24
Broodie -
Well, the governing factor is where your "regular place of residence" is - and in what State your MDL is issued.
If you have a W.A. MDL, and your "regular place of residence" is W.A. - then if you buy a 'van in VIC or QLD - and it's already registered - then you can apply to have it re-registered in W.A., without moving it - provided it's under 4500kg GVM.
If you have a W.A. MDL, and a W.A. address, and you try to transfer the VIC or QLD registered 'van into your name, using the same VIC or QLD rego number - then the authorities will refuse to do the transfer.
I already have recent personal experience of this, after buying a ute in VIC and trying to transfer the VIC rego into my name, using a mates VIC address. VicRoads refused to carry out the transfer. I have a W.A. MDL and home address - and the MDL state of issue, governs the whole deal.
If you change your "regular place of residence" to VIC or QLD - you're obliged to transfer your W.A. MDL (within 30 days) to a VIC or QLD MDL, to match your "regular place of residence".
Once you do this, transferring ownership into your name, using the same VIC or QLD rego is a cinch.
Here's some tips and hints:
1. Watch out for the substantial difference in stamp duty and transfer costs, that vary quite a bit between States. This cost is often ignored by purchasers - but on a sizeable sum, it can be $1000 or more.
2. W.A. registration is preferred by most travellers, as W.A. licencing conditions are more owner-friendly than many other States. You have no requirements for annual inspections or "pink or blue slips". Annual inspection cost is an additional cost burden.
3. W.A. rego can be let lapse for 3 mths before needing renewal. However, you can't use the vehicle/trailer/van on the road after 15 days beyond the end of the rego period, as this is the limit of the insurance cover time.
4. W.A. rego is usually cheaper than other States.
5. The only downside to W.A. rego is our insurance policy is a "fault" insurance system - not a "no-fault" system. VIC, NSW, TAS and the N.T. all have "no-fault" insurance in their registrations.
This means if you have an accident with a W.A.-registered vehicle - and you are injured/killed as a 3rd party - then you, or your NOK have to go to court to prove fault and liability.
The Gillard Govt tried to get States to agree on a nation-wide NF system, but it hasn't happened yet.
http://www.theaustralian.com.au/national-affairs/state-politics/states-urged-to-agree-on-no-fault-car-insurance/story-e6frgczx-1226269152038
797717
