New plastic water tank 'taste' ??
Submitted: Monday, Jul 22, 2013 at 16:56
wombat100
Hi all
Would anyone recommend a 'fix' for removing the taste in a new plastic
water tank. The
tank is 100litres- fitted to a new campervan.
Wombat
Reply By: Notso - Monday, Jul 22, 2013 at 17:09
There are lots of recommended fixes for this,
I did this and it seems to work Dissolve about 500grams of BiCarb Soda in a bucket of warm
water and pour it into the tank, then fill it right up. Leave it soak overnight then drain and rinse and refill.
Others recommend a bit of household bleach and do the same as above.
One thing to make sure of it that you only use food grade hose to fill the tank and as a supply hose for the van.
515177
Follow Up By: kev.h - Monday, Jul 22, 2013 at 17:22
Yep second the Bi-Carb Soda works a treat
794352
Reply By: Member - Phil G (SA) - Monday, Jul 22, 2013 at 18:23
As
well as Notso's suggestion, it may not be the
tank.
#1 don't use a garden hose to fill the
tank - might be the source of the plastic taste. Best hose I've found is the braided light blue
drinking water hose made by Nylex or Neta. I had bad plastic taste in the past from Pope brand
drinking water hose.
#2 The hoses used to plumb your
watertank might also be the cause. If the first glass of
water is bad and after running more from the
tank, its OK, then blame the hosing.
515183
Reply By: Sand Man (SA) - Monday, Jul 22, 2013 at 18:32
Milford's baby bottle wash is what I use.
Comes in a 1 litre plastic container and from memory, the measure is 50ml per 1l of
water.
In your case, add half a bottle to the
tank and fill it up and leave it for a couple of hours or so.
Then turn on the outlet tap to flush a bit through the plastic tubes, then drain the lot.
Refill with clean
water, flush the outlet tube, drain again then fill the
tank with clean
water for the final time.
I also use a
water grade hose to fill the
tank of my camper as cheap garden hoses will just taint the
water taste again.
515184
Follow Up By: Sand Man (SA) - Monday, Jul 22, 2013 at 18:33
Aw bugger, I just had a seniors moment.
That should be
Milton's baby wash. Available in any
supermarket.
794363
