tubless valves should they be replace when buying new tire
Submitted: Tuesday, Jul 02, 2013 at 13:00
allein m
I was shocked yesterday to find that when I had some new tires put on to our vehicle they had not replaced the tubless valves
I bought the tires 6 months ago and have already had one tire go flat in town for no reason that was repaired by the company i bought the tires from they replaced the valve
but we got two flat tire on the way to
Adelaide and they were changed by a different tire place in Peterburgh he said the tubeless valves were leaking and defiantly had not been replaced so I asked him to remove the two other tires and the too had old tubless valves
all fixed now but is this common not to replace the tubeless valves or just a way to keep prices down it was a
young boy who had worked on the car the first time he even got the tire presures wrong i will be more carefull when i purchase new tires from now on
we have sent a email to the company but no reply so far
Reply By: Member - Tony H (touring oz) - Tuesday, Jul 02, 2013 at 15:03
I believe it is good common practice to replace the tubeless valve stems when replacing tyres, but NOT mandatory.
I do
check myself when having new tyres fitted, that new stems have been fitted.
514135
Reply By: John and Regina M - Tuesday, Jul 02, 2013 at 16:18
Have never had them replaced in 40 years and never had a problem.
But why 'shocked'?
I know some people who religiously replace them every tyre replacement. Guess no harm.
I reckon wheel nuts take more stress. But I'm not 'shocked' they don't replace them.
514138
Reply By: Member - Andrew - Tuesday, Jul 02, 2013 at 16:30
They are subject to Ozone deterioration just like your tyres and if not changed can be the source of that hard to find slow leak due to micro cracking and splits as
well as losing the flexibility needed to keep a seal in the mounting hole in the rim. They do flex a lot under centrifugal loading and of course they also suffer the odd stone and stick hit.
The guys I use always replace them, generally because they cut them off to deflate the tyre fully when dismantling.
Always been told that fitting new ones with new tyres is best practice. (Have to remind them about the TPMS!)
And then some people never have a problem with not changing them.
regards
A
514140
Reply By: Member - Phil G (SA) - Tuesday, Jul 02, 2013 at 22:22
Tubeless valves are only $2 each.
Every time I've bought tyres, the tyre fitter puts new valves in, and I'd be miffed if they didn't.
514165
Reply By: blown4by - Tuesday, Jul 02, 2013 at 22:42
Most reputable tyre dealers will replace the tubeless valves as a matter of course when fitting new tyres on the basis that they do not last a lifetime and it is just good industry practice to replace them rather than have the customer return with a slow leak from that source. Unlike steel wheel nuts, being rubber they are susceptible to ozone, UV, heat and mechanical damage including cuts from ill fitting wheel covers. I got caught about a year ago when having 4 new LT tyres fitted to a tandem trailer and the dealer failed to repalce the tubeless valves (I didn't
check) While travelling at night with a car on the trailer, about 2100kg all up, after about 600km I stopped for fuel and could smell hot rubber. One of the tyres had defelated to about 15 PSI because the T/L valve was leaking so I fitted the spare. After another 400Ks I stopped for the night and next morning another tyre was flat. When I went to re-inflate the tyre the brass insert in the T/L valve (which the valve screws in to) blew out and nearly took my eye out on the way past my head. Had I not noticed the first tyre losing pressure at best I may have wrecked the new tyre, at worse it could have caused a tyre fire (near impossible to extinguish) or caused a difficult to control situation. When I returned to the dealer and expressed my disappointment they did not believe they had not replaced the T/L valves until I showed them the valves still had blue over spray on them from when the trailer was painted some years prior. I would say this was a case of the tyre fitter forgot or lack of training but as this occurred within a few days of having the new tyres fitted rest assured if this incompetence had resulted in any tyre damage I would not be paying for their reaplacement.
514167
Reply By: The Bantam - Wednesday, Jul 03, 2013 at 09:54
As other posters have said, there is no good reason to not replace rubber tubless stems every time a tyre is fitted.
As for a tyre
shop getting the tyre pressure right....don't make me laugh.
In over 30 years of driving and buying tyres I have not once come away from a tyre
shop with the correct pressure in the tyres.
Some deliberately over inflate and say that they do, because it "helps
seat the tyres on the bead" and advise adjusting the pressure after the vehicle has been driven on the tyres
Others just seem to have their own ideas on tyre pressures....almost always over inflated and considerably so.
Never, trust a tyre
shop to correctly inflate your tyres and be very wary of any advice from a tyre
shop concerning tyre pressures.
They should no better....but they mostly just don't.
514188
Follow Up By: BrendanKLR650 - Wednesday, Jul 03, 2013 at 19:51
I'll second that.. Any time I get new tires on my bike, I ALWAYS zip to the closest servo to
check and usually change the pressures.
793141
