NP Pajero clutch kit
Submitted: Saturday, Jun 29, 2013 at 20:21
Justin W3
Hi all, Have been quoted $2,900 for a non dual mass clutch kit replacement for my '04 NP Pajero. Is this a reasonable price or should I
shop around ? We're off to
Ningaloo next weekend and need to replace before ? Any recommendations ?
Reply By: Justin W3 - Saturday, Jun 29, 2013 at 20:35
Forgot to say we are in
Perth north of river.
513993
Follow Up By: member - mazcan - Sunday, Jun 30, 2013 at 13:13
hi justin W3
that sounds like a rip-off to me
give this guy a ring at
Australian differential and transmission service
ADTS
77b Collingwood st Osborne pk
ROB 94439299 or 0419422246
he rebuilt a transmission for me feb 2012 and is reliable very experienced and a decent guy to deal with
very open and honest and will answer your questions if you want to know anything and wont rip you off
I can highly recommend him
cheers barry
792883
Reply By: Michael ( Moss Vale NSW) - Saturday, Jun 29, 2013 at 20:40
Is that a new flywheel with it? You may be surprised what a genuine clutch and fitting may be with dealer fitting! Nissan want around$600 for a kit and $700 to fit! And you get a warranty if they bother to honour it! Thats a standard kit for a 4.2 td. Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
513994
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Jul 03, 2013 at 20:27
Quote ,,,Of course it includes a new flywheel. It's no good putting a new clutch back on a dual mass flywheel if you are having failures. Here is some reading for you.
Peter, He didn't say he was having problems or failures, he said he needed to replace it. Michael
| Patrol 4.2TDi 2003
793146
Reply By: fisherPete - Saturday, Jun 29, 2013 at 21:26
That's the dearest price I have heard of. Let your fingers do the walking and get some other quotes. Small private garages are usually cheaper.
Cheers Pete
513997
Reply By: Ross W7 - Saturday, Jun 29, 2013 at 23:13
Hi Justin.
I believe you should be able to purchase a replacement aftermarket single mass clutch considerably cheaper than that if you ring around. A quick look online suggests a similar price for a range of 4WD's and commercial utility type vehicles. I think it wise to replace with a single mass unit from my investigations.
I replaced the dual mass clutch in my 2008 Ford
Ranger in Feb this year at 70k, severe rattles from flywheel springs at idle.
The single mass clutch replacement kit included new flywheel, clutch plate, thrust bearing, new H/T clutch bolts and alignment tool. The whole kit cost $1150.00 from Wrights Clutches in Lismore NSW. The clutches would be of a similar size and should I believe cost within a $100.00 or so of this price.
The fitting cost for the
Ranger was $450.00 at a local workshop (large country town) which I believe to be very reasonable. It appears to have greater clamping force without a hard pedal and has a smooth action.
Its interesting that many of these OEM dual mass units in a range of brands including Mitsibishi are having short lived lives not being necessarily related to abuse.
Mine was smooth and showed little wear ,no hotspots or oil contamination.
I note that Ford and Mazda have returned to fitting single mass clutches in their latest Rangers and BT-50 and have been told other manufacturers are doing same.
Note that dual mass clutches are supposed to relieve vibration and be smoother, however at the cost of more complexity and don't do
well with loads outside their design loading parameters.
Trust this assists,
Ross.
514006
Reply By: awill4x4 - Sunday, Jun 30, 2013 at 16:04
Justin is the price you quoted including fitting or supply only?
Here are some examples from Fleabay and even the most expensive are over $1000 cheaper on a supply only basis.
Regards Andrew.
Exedy clutch kit Qld.Exedy clutch kit MelbourneExedy clutch kit NSW
514032
Follow Up By: Justin W3 - Sunday, Jun 30, 2013 at 17:57
Hi, as quoted it's $2,200 for the kit (2nd price he found was $2,800) & the remainder is for about 6 hours of labour.
Becoming more & more dubious. Thx for the advice everyone !
792905
Reply By: Member - poppasmurf - Sunday, Jun 30, 2013 at 22:21
We have a 2006 NP Pajero and had a new clutch kit fitted with solid flywheel and paid $1800 fitted by our local Mitsubishi dealer a few months ago so $2900 sounds way over the top. We live in
Moonta Yorke Peninsula SA. Hope this helps.
514055
Reply By: adtrac - Monday, Jul 01, 2013 at 19:00
I have been quoted two prices for clutch replacement both are with dual mass flywheel, they were $3065 and $3400 including fitting to 2002 np pajero at mitsubishi dealers.
What you have been quoted is steep for a single mass set up in my opinion.
514089
