Wander lead for Terlin HF antenna
Submitted: Thursday, Jun 27, 2013 at 20:41
ThreadID: 102990 Views:4514 Replies:2 FollowUps:4
G'day,i need a new wander lead for my multi tap terlin outbacker hf antenna,i called into outbackers place in Canningvale when i was down in the big smoke (perth) last week but looked like the shop was closed up.i have tried the phone number but no go,
Doe's anyone know where else i can get one from.
Thanks in advance,
cheers, sparra
Reply By: Member - Joe F (WA) - Thursday, Jun 27, 2013 at 23:31
G'day sparra
Give Bush comms a look, they make their own multi tap antennas but I am sure they can make a wander lead for your particular antenna, or simply make your own !
www.bushcommantennas.com.au
They are in Bayswater ~ Perth WA
Safe travels :
AnswerID: 513893
Reply By: exmouth1 - Thursday, Jun 27, 2013 at 23:36
G, day sparra I will be in Perth tomorrow night and I have a couple of Wanda leads that you can have.
Will be in Wilson 0427777255
AnswerID: 513894
Follow Up By: Member - sparra - Friday, Jun 28, 2013 at 06:52
Thanks for the offer john but i am 900klms north of perth,i will catch up with one of our sparkies at work today.
thanks again,
cheers, sparra
FollowupID: 792721
Follow Up By: get outmore - Friday, Jun 28, 2013 at 07:06
At the base of your arial it should have the length of it . Make sure you get one the right length
FollowupID: 792723
Follow Up By: Member - sparra - Friday, Jun 28, 2013 at 08:13
Yeah no worries ,thanks gom,it's WL110.
FollowupID: 792728
Follow Up By: Member - John and Val - Friday, Jun 28, 2013 at 08:57
You can easily make one yourself with a couple of banana plugs from Jaycar and the correct length of insulated wire. As Getoutmore says, on a Terlin antenna you'll find the required length (cm) printed at the bottom of the fibreglass rod.
J and V
- Albert Einstein
FollowupID: 792731
