Thursday, Jun 20, 2013 at 18:29
Bad vibration is something moving in a way you don’t want it to.
How bad is subjective but the consequence can be catastrophic depending on what is affected.
As J & R has suggested, diagnosis is crucial to solve the problem without unnecesary work being done.
When did the problem start?
Did it happen suddenly or over a long period of time?
Does it change with road speed or only with engine revs?
Does it change when you accelerate and then back off or coast in neutral?
Does it change with different road surfaces?
Does it get better or worse when you corner?
Explaining this type of thing to competent mechanic and letting them roadtest the vehicle to get a feel for what the vehicle feels like is the start of the diagnosis process.
Remember also that a wheel balance does not always solve wheel vibration issues. The tyres may not be round, may be uneven in their “stiffness”, or the wheel may not be true on the hub. If the wheel balance was done “off” vehicle and they didn’t know you were chasing a problem, then they may not have checked for everything.
On smooth roads vibrations are mostly caused by things that spin. On rough roads the uneven surface makes things move. So, tyres, wheels, driveshafts, CV joints and universals usually show up on smooth roads while worn
suspension joints and mounts are more likely to vibrate on rough roads. However if you have badly out of balance wheels and worn
suspension joints for example, then the vibration can be much worse.
As you can see it’s almost impossible to effectively assist such a general enquiry without a lot of background.
A
513475
