Codan 9323 power problems
Submitted: Sunday, Jun 09, 2013 at 15:15
ThreadID: 102678 Views:3740 Replies:4 FollowUps:5
Gday all,
Long time since I posted here but keep a close eye on all that is going on.
I have a problem with no power on my 9323. I believe that I have blown an internal fuse but am unable to locate any fuses within the radio and a thorougher search on the web gives me an indication that fuses exist but no location information. It also states that no fuses are in the remote head.
Any help would be greatly appreciated.
Lewis
Reply By: Member - John N (SA) - Sunday, Jun 09, 2013 at 16:17
G'day Lewis,
The only fuse I am aware of in my 9323 is at 32A one in the ceramic type holder in the power lead that plugs into the main body. (I also have a further fuse near where the lead comes off the battery).
AnswerID: 512849
Follow Up By: Travelinglew - Sunday, Jun 09, 2013 at 17:01
Thanks John,
That 32A fuse is supposed to be located at the battery and is designed to prevent the power cable from causing issues if it shorts back to the body of the car (according to the Codan manuals). They do talk about further fuses and protection inside the main unit........
Your guess is as good as mine
Lewis
FollowupID: 791383
Reply By: The Explorer - Sunday, Jun 09, 2013 at 18:28
Hello
I have no idea but a search of the yahoo codan outback radio group forum showed a person with the same/similar problem - which stated:
"I found the fault - it was a blown fuse on the A pair "
No idea what the "A pair" is.
Maybe asked the question on the forum..
http://groups.yahoo.com/group/codan_outback_radio/
you will probably have to register first.
AnswerID: 512852
Reply By: Echucan Bob - Monday, Jun 10, 2013 at 00:27
Lewis,
Here is the Service Manual
Section 5 has a fault finding tool.
AnswerID: 512867
Follow Up By: Travelinglew - Monday, Jun 10, 2013 at 07:25
Thanks Bob,
Went through this a couple of days ago and could not find any reference to the location of fuses. Only reference I could find was in the glossary.
Will try giving Codan a ring tomorrow when they are back at work.
Lew
FollowupID: 791405
Follow Up By: cookie1 - Tuesday, Jun 11, 2013 at 13:35
That is fantastic, wouldn't happen to have a copy of the NGT Service Manual?
FollowupID: 791520
Follow Up By: Travelinglew - Tuesday, Jun 11, 2013 at 15:16
Sorry cookie1. Can't help with that. Might be worth you giving the HF radio club a try though
Lewis
FollowupID: 791528
Reply By: Stu & "Bob" - Wednesday, Jun 12, 2013 at 21:54
There are a couple of fuses in the PA section of the radio. If you take the big cover off,
you should see them near the red and black power cables.
They look like bits of wire soldered to a couple of posts on the board.
HTH
AnswerID: 513015
Follow Up By: Travelinglew - Thursday, Jun 13, 2013 at 08:28
Thanks for the info. I was caught out as they looked like test points rather than fuses. One of these is blown so once I source a suitable fuse wire, it should solve the issue.
Thanks to all that responded to this problem. Your help has been greatly appreciated. Hopefully a little bit of knowledge gained by all who have had a read.
Lew
FollowupID: 791660
