Searching for a led light fitting for the caravan
Submitted: Sunday, Jun 09, 2013 at 14:47
carlj
I want to replace the old light fitting in my van with a led fitting, has to be appox 400mm long and no higher than 15mm. Have searched the internet without success. Any info would be great.
Reply By: craigandej - Sunday, Jun 09, 2013 at 16:13
Hi try Bunnings, they have a new range of under cabinet LED lighting, both 240V or 12V with transformer which you could bypass if you want 12V only.
512848
Reply By: ed c1 - Sunday, Jun 09, 2013 at 20:18
hi carlj,
if you are from
sydney or other,,try koloona industries at minto
p:02 9820 5233 f:9820 5244 only a small place but heaps of help and the price is right....talk to patric....can help you to convert your normal fittings to led s or smd,s .. me just a happy customer
512857
Reply By: Ozhumvee - Sunday, Jun 09, 2013 at 21:02
Might be easier and cheaper especially if it is an older van to just fit LED globes or panels to the existing fitting.
I've done it successfully on a few now after others have seen
mine and been told about the resulting power consumption drop.
I've bought
these type with great success. If your fittings use a different globe to the ones supplied just break the existing globe out of the metal socket and solder the wires straight into it or bypass the socket and connect direct to van wiring.
I've been buying them in lots of ten or more as everyone wants them.
512859
Follow Up By: carlj - Sunday, Jun 09, 2013 at 21:16
I have a 2006 Coromal Capri XC, I have fitted led bulbs to most of the light fittings. The problem is that the roof mounted fluro in the back of the van has melted the plastic fitting was very lucky we didn't lose the van. I am in
Roma central Queensland but can buy most things over the internet so not to concerned where to go, just need a lead to a supplier.
791399
Follow Up By: Rockape - Monday, Jun 10, 2013 at 06:52
carlj,
I just replaced the fluros in my coromal van with led's form ABR Sidewinder.
If you scroll down the link you will see them. 12 inch 36 LED Roof Lamp with switch.
ABR LINK
To use the old mounting points I cut up a $10 nylon breadboard to the same shape as the new lights and then fitted that behind the lights You can just drill and tap the board to secure the new light.
They are pretty low profile being on 33mm high and the light is far better than a fluro.
791404
Reply By: Member - Scott M (NSW) - Sunday, Jun 09, 2013 at 21:22
