Sunday, Jun 02, 2013 at 17:01
Phil,
Bruce n Bundi nailed it in one
not as many people in the bush and far less idiots who are unknown to you so chance of gettig bingled almost miniscule.
Dermie ,
the
water tank is mounted under the front of the trayon the drivers side and rear of it is
well in front of xmember that goes above diff.
to fit the gerry cans I have to remove split rim which is my second spare from under tray and put it in the canopy with main spare.
I then have a piece of 16mm chipboard which goes in on top of spare wheel rack above rear tank.I then put a wire basket made fron 2" square mesh and lined with carpet on top of the board. 3 gerries fit between chassis rails of tray, if laid on their side and parrallel with chassis rails, another 2 gerries fit across behind them just inside rear door of tyre rack . I had to relocate the door back about 2 inches so the 5 cans fitted behind the xmember above the diff.I have strips of foam that go between cans to stop them rubbing and also jam a layer of rubbermats on top to stop cans bouncing
the fit is so close i didnt even have to tie them down for the trip across
madigan line.
dont have any photos but willl be going on trip in next month and will take some when i refit. just PM me so i have an address.
I also have a rack for a single gerry on each side behind the mudguards and in front of taillights.
Howard
790721
