Nowra to Canberra
Submitted: Wednesday, May 15, 2013 at 15:59
ThreadID: 102224 Views:5349 Replies:3 FollowUps:4
Could anyone tell me the best road to take over the mountains from Nowra to Canberra towing a 20ft Van with a Holden Colorado. Is the easiest way up the Clyde or through Kangaroo Valley, I think there is another road across there also through Nerriga I think. ? condition of this road
Reply By: garrycol - Wednesday, May 15, 2013 at 16:32
Simplest is Nowra, Nerriga, Braidwood, Bungendore and Canberra.
Slightly shorter is Nowra, Nerriga, Oallen Ford, Tarago, Bungandore and Canberrra.
I did that trip the other way on Friday.
AnswerID: 511105
Follow Up By: Pelikan - Wednesday, May 15, 2013 at 18:13
Less dirt via Tarago.
FollowupID: 789223
Follow Up By: Cravenhaven - Wednesday, May 15, 2013 at 18:46
I think the simplest and flatest way is the Nowra/Nerriga/Tarago route. There is a short section of gravel/dirt road across the river, but most of the way is good quality sealed road.
I would suggest that you dont take the Kanagaroo Valley way as the road up the hill to Fitzroy falls is steep and windy (ie curves, NOT air movement :) )
cravenhaven
FollowupID: 789224
Reply By: Member - Toyocrusa (NSW) - Wednesday, May 15, 2013 at 20:52
Hi Chery. I did the Nowra to Braidwood road through Nerriga last week.Nowra to Nerriga is a good tar road. Nerriga to Braidwood is dirt and a bit narrow in sections. We had two logging trucks pass us going in the opposite direction and I would not have liked to be towing our 22ft van at the time as there is not a lot of width. I am not sure if Nerriga to Tarago has logging trucks on it but it sounds a better proposition. Cheers,Bob.
AnswerID: 511127
Follow Up By: Patrol22 - Wednesday, May 15, 2013 at 21:28
I commuted along the Nowra-Nerriga-Oallen Ford-Tarago-Bungendore-Caberra route for 2 years - it is a very good run with no log truck. There is a short 2 km section of gravel between Oallen Ford and Tarago but this was in very good condition. The run is approximately 1 hr 55 min but some may do it quicker than me. Traffic is usually quite low.
FollowupID: 789254
Follow Up By: RedCherokee - Thursday, May 16, 2013 at 22:15
Definitely Nerriga then Oallen ford and Tarago. Saves having to tow through KV.
FollowupID: 789354
Reply By: Nomadic Navara - Thursday, May 16, 2013 at 23:32
Via Kangaroo Valley is slightly shorter than via the Clyde.
When are you going? Clyde Mth will be closed to all traffic on Tuesday, Wednesday and Thursday from 28 May to 27 June. The Nerriga route will be rather busy during those days although I think it will be closed to trucks.
See the RTS live traffic site.
AnswerID: 511199
