no gears in 96 hilux
Submitted: Wednesday, May 15, 2013 at 07:51
daggs
suddenly lost all gears in Hilux LN106, there was a mild clunck noise then nothing. Any ideas?
Reply By: olcoolone - Wednesday, May 15, 2013 at 08:15
If I was a betting man I would say it could be your transmission.....somewhere.
It could be one of many.
511077
Reply By: timothy - Wednesday, May 15, 2013 at 09:58
You haven't bumped the transfer case into neutral have you? That's the quickest way to lose all gears.
511085
Follow Up By: landseka - Wednesday, May 15, 2013 at 10:08
or break an input shaft. I would be hoping for yours though Tim.
789192
Reply By: Steve D1 - Wednesday, May 15, 2013 at 10:21
the sleeve on the back of the output shaft to the transfer will have broken. Fairly common.
Sorry, cant supply a
pic, as not "financial Member" anymore.
Cost around $100.00
Steve
511086
Follow Up By: Steve D1 - Wednesday, May 15, 2013 at 10:29
try this link to TOYODIY. You may need to register. Free.
it's item 33389
TOYODIY
Steve
789194
Follow Up By: daggs - Friday, May 17, 2013 at 08:19
thanks Steve, it ended up being the clutch, it completely failed, we were a little bewildered after checking the gearing and not finding any problem, a quick look at the clutch revealed the problem. clutch was not very worn, so just unlucky I guess. cheers
789381
Reply By: Motherhen - Thursday, May 16, 2013 at 00:32
Hi Daggs
Sounds like what happened to us in our Landcruiser once; all gears gone from the one clunk which we thought would have only taken out one gear. A night of drama getting recovered and a few thousand $$s to get gearbox rebuilt :(
511142
