hf radio
Submitted: Monday, May 13, 2013 at 19:00
BOXHD
Hello members looking at hf radios ..l Would like to know if there are compack ones as i like to fit it into a roof console ...And wht are the best brands ..
cheers Boxhd
Reply By: wombat100 - Monday, May 13, 2013 at 19:16
Probably the most compact in size is the Qmac HF90- although that may even be a bit big for roof console mounting !!
511004
Reply By: olcoolone - Monday, May 13, 2013 at 21:22
Best thing to do is use one with a remote head, our Icom IC-F7000 has a small din size remote head.
There is only three HF radios I would recommend, Icom, Codan and Barrett...... all three are on par with each other and it comes down to personal preference.
511019
Follow Up By: BOXHD - Tuesday, May 14, 2013 at 11:10
hi Olcoolone.. had a look at them they look pretty compact and would suit quite
well ...cheers boxhd
789148
Reply By: Member - Markthemilko - Monday, May 13, 2013 at 22:06
Hi BOXHD,
I have a Codan NGT which is mounted high up (out of reach of water) in our purpose built 'camperback', where it is more secure (from theft) than in the ute cab. In the cab are the speaker and the handpiece with all the necessary controls. I also have a water-proof (Sea to Summit) bag should we have to abandon the vehicle 'in the wet' ! The Codan - and perhaps others - are clipped in a bracket which is securely fixed to where-ever, and can be quickly removed & cables unscrewed.
You'll need a licence to operate it which is easily obtained if you join a radio club such as VKS 737 etc.
511020
Reply By: MEMBER - Darian, SA - Tuesday, May 14, 2013 at 08:30
Agreed that the console seems impractical for a radio, but maybe workable for a remote head.....keep in mind that some makes/models have all controls within the microphone.... one make/model has a cordless remote head that is also the mike ! ...you can put it anywhere. That said, HF radios sometimes need brief input to the interface as you manually config various functions and tasks while mobile..... IMO, having it up on the roof is less than ideal ergonomically....much better in your 'straight ahead' field of view.
511029
Reply By: Echucan Bob - Thursday, May 16, 2013 at 22:18
