Sunday, May 05, 2013 at 12:57
Oldcoolone...mate where do I start.
lets look at simple beam axles on leaf springs.
the land cruser chassis is not a straight flat piece of steel, the front spring hangers are lower than the spring shackle attachment points allowing the spring to sit at the correct attitude and not inclined about 20deg.
It also allows the axle to travel further and the spring to work thu its entire reasonable acting travel.
The springs on the land cruser are very long in comparison to a trailer of similar capacity, thus making the ride softer and smoother for the same spring rate.
the springs are also flatter as
well as being longer, thus reducing bump steer and forward and aft movement of the axle as the spring acts.
The springs of far better quality and the spring rate and progression has actually be designed for that vehicle and load rather than just being pulled out of a catalogue.
If you complain about the factory springs being poor in landcrusers .....hell there are aftermarket springs that have had more R&D and engineering attention for a single spring for a single model than goes into most entire caravan manufacturing plants ever.
The landcruser is fitted with bump stops, by far the majority of trailers are not.
because the chasis is not a straight beam it allows the shock absorbers to be fitted correctly and not as some obtuse angle.
The shock absorber rates have been designed for
the springs and the load carried...
OH...there are shock absorbers..still the majority of trailers and caravans have none.
Now the axle....OK the landcruser axle is a driven axle...but if it was a 2wd machine of similar weight, the axle stubs would be heat treated and properly machined with fairly fine threads on the bearing adjustment....not a lump of cheap chineese steel that is one step better than mild steel, fairly roughly machined, not heat treated and with threads on the bearing adjustment that result in the bearing preload either being sloppy or over tight.
Most trailer axles they don't even scrub the mill scale off them before they slash a thin coat of black paint over everything under the thing
Then there are the bearings......most trailers even quite heavy ones run on bearings out of a 50 year old passenger car front end either an early holden or and early falcon...and then cheap chinese versions.
Mostly they would rather put two cheap axles with cheap 50 year old passenger car bearings on them that a single decent axle with ample modern bearings
Pull the bearings out of ya trailer and compere them to those out of the front of ya land cruser and tell me if there is a difference
and the same goes on....in every area.
There is no requirement for formal stability or crash testing in fact the whole required standards for light trailers in the ADRs less than 1/4 of the of the text devoted to headlights in passenger cars.
As for these jokes that they sell as independent
suspension....OH HELL...you might not break it, but they have nowhere near the geometric sophistication that you would find in a 50 year old passenger car with independent
suspension.
most of them is something that a bloke welded up in his back shed...if ya lucky he used a jig and is a competent welder
Then there are the wheels and tyres...a great many trailers especially caravans are pushing the envelope of not only the tyre fitted, but the load carrying capacity of the rim and the, load carrying capacity of tyres available to fit that size of rim.
Go
check the load carrying capacity of the tyres factory fitted to ya landcruser and look at how much spare capacity is available in that tyre.
Even the very notion of light trailers as we know them has progressed little in 50 years.
In heavy transport, long heavy trailers with a high centre of gravity running on a single axle group are actively discouraged...because the format is fundamentally unstable......articulated vehicles and dog trailers with the loads supported at the ends are the norm because they are far more stable.
we see almost no dog trailers behind passenger cars and articulated only in the rediculoulsy large trailers.
I do not wonder why people have all sorts of problems with trailers.......almost without exception light trailers are very crude and as caravans most are fundamentally unstable.
because they are fundamentally unstable those who tow large trailers and caravans have to spend $$$ on
suspension upgrades in the vehicles and on load distrubution and sway reduction devices.
788468
