Bushranger Mudflaps
Submitted: Tuesday, Apr 30, 2013 at 18:23
craigandej
As the troopy now has 285/75/16 under her, I need to upsize the rear mudflaps. Bushranger have a pair available in a size that will suit. Has anyone had any experience with them, or can you recommend any others?
Craig
Reply By: andrew t - Tuesday, Apr 30, 2013 at 19:19
i have a long mudflap of a truck, rear dual wheels cut in half and it does the trick real fine on my troopy tried some of the others and they are too short to be any good, they work fine are cheap and are easy to work with,
510055
Reply By: Member - MUZBRY(Vic) - Tuesday, Apr 30, 2013 at 19:31
Gday
The better the mud flap, the more chance you have to rip off a mud guard .
510056
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Apr 30, 2013 at 23:16
The other problem is the lack of air under the vehicle to cool the drive train. Especially if have the entire width of the vehicle covered in mudflaps! Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
788125
Reply By: Penchy - Wednesday, May 01, 2013 at 08:00
maybe ask drivers behind you if your mudflaps are doing their job?
510091
Reply By: Member - David M (SA) - Wednesday, May 01, 2013 at 09:17
G'day Craig. Tried a few types on
mine and none lasted all that long. ln the end I bought some 5mm from Clarke Rubber and made my own. Simple to make up to any size and a far better result.
Cheers,Dave.
510099
