Thursday, Apr 25, 2013 at 14:41
Road Transport (Vehicle Registration) Regulation 1998
34 Rear vision mirrors
(1) A rear vision mirror or mirrors must be fitted to a motor vehicle as required by this clause so that a driver of the vehicle can clearly see by reflection the road behind the vehicle and any following or overtaking vehicle.
(2) At least 1 rear vision mirror must be fitted to:
(a) a car, and
(b) a motor trike with 2 front wheels, and
(c) a motor bike, or motor trike with 1 front wheel, built before July 1975.
(3) At least 1 rear vision mirror must be fitted to each side of the motor vehicle:
(a) if the vehicle has a GVM over 3.5 tonnes, or
(b) if the vehicle is a motor bike, or motor trike with 1 front wheel, built after June 1975, or
(c) if the vehicle is constructed for the carriage of goods (not being a station wagon), or
(d) if the vehicle is a bus, or
(e) if the maximum width of any trailer or other vehicle drawn by the vehicle is greater than that of the vehicle, or
(f) if because of the manner in which the vehicle is constructed, equipped or loaded, or because of the fact that the vehicle is drawing a trailer or other vehicle, or for any other reason, the driver cannot, by means of a mirror fixed to the interior of the vehicle, have reflected to him or her as far as practicable a clear view of the road to the rear of the vehicle and of any following or overtaking vehicle.
(4) A motor vehicle with a GVM not over 3.5 tonnes (except a motor vehicle mentioned in subclause (2) or (3)) must be fitted with:
(a) at least 1 rear vision mirror on the right side of the vehicle, and
(b) at least 1 rear vision mirror on the left side of the vehicle or inside the vehicle.
(5) A rear vision mirror fitted to a motor vehicle with a GVM over 3.5 tonnes must not project over 150 millimetres beyond the widest part (excluding lights, signalling devices and reflectors) of the vehicle or combination.
(6) However, the rear vision mirror may project not over 230 millimetres beyond the widest part of the vehicle or combination if it can fold to project not over 150 millimetres beyond the widest part.
509750
Follow Up By: Pathycop - Thursday, Apr 25, 2013 at 15:16
John. Many thanks for your thorough research. If you go back to my original reply at the top of the page I stated that I was going to avoid being technical and keep it simple which I believe I have done in my replies. If you wish to be technical then that's fine with me. I probably know my job and the rules and regulations better than you as you will know your job better than me. It was supposed to be simple answers to a simple question no need to get into vehicle regs. I can inform you with qualification that whilst there are various offences relating to rear view mirrors etc, the SPECIFIC offence is road rule 297. This is the rule we as police use on the road everyday. It does not specify how you obtain your rear view and it is clear and simple for anyone to understand.
I think a simple explaination can usually be appreciated by most if it provides the information required to avoid a fine with out clouding the answer with quoting clauses and sub clauses. Although I am sure some will appreciate the nuts and bolts also.
Graeme
787749
