To snorkel or not to snorkel
Submitted: Monday, Apr 22, 2013 at 23:02
oliver p
Hey guys, i have just recently bought myself a Toyota Hilux 1994 dual cab with the 2.8 litre ln106r diesel engine. She has around 270000 km with a few additions such as raised aftermarket
suspension (not sure on much else about the
suspension),
uhf radio, winch, spotlights and some offroad tyres.
So basically my question is, to get a
snorkel or to not get a
snorkel. I would be getting one off eBay which will cost me around the $100 mark. I will be doing some off roading soon, as a go hunting in national parks and on farms so its mainly dirt tracks, nothing too tricky. I was thinking the
snorkel might help out the fuel economy/power slightly? with the advantage of being able to cross deeper water. What is everyone's thoughts?
Reply By: Batt's - Monday, Apr 22, 2013 at 23:25
You can cross deeper water but remember if you plan to cross a
deep creek or something put something the front of the vehicle to slow down water ingress to help protect your alternator and other electrical items. I gained about 0.5ltr per hundred km economy & a small power gain there definitely worth putting on . I no nothing about the cheap one's as long as they channel the water away correctly are made of sturdy plastic & is big enough to supply enough air I suppose it would be ok. I have only had tjm snorkels before and point the
snorkel head forward the way they are designed to be used even in torrential downpours they won't suck water into your motor.
509572
Reply By: mountainman - Tuesday, Apr 23, 2013 at 00:31
your biggest restriction is the air box air intake, no more than 50mm wide.
i cut that out and fitted a 3inch inlet, she breathes now, goes
well for a 2h.
trouble with a
snorkel you buy, they come with 2mtrs of hose to connect from the
snorkel to the filter, reducing any benefits..
that was for my vehicle, landcruiser, maybe not yours.
you should be right without it, it will help the 2.8 breathe better, but still your stuck with the 2.8 power, or lack there of, mind you you got pretty good economy..
hilux's are generaly have high clearance from the factory, and youd have to be going into some deep crossings to drown an engine, or drive stupid across a river to do damage.
its only a 100 bucks soo yeah not much money to install some extra safety for your engine.
509574
Reply By: Michaeljp - Tuesday, Apr 23, 2013 at 03:35
After 22 years, 2 hiluxs '89 model and a '96 model and nearly 1,000,000 km between the 2, the best thing to do to your hilux is put extractors on it. It will make more of a improvement than the snorkle will.
For deep water just disconnect the plastic pipe that comes out of the air box and goes into the intake. Its about 6 -7" long and you just need a large phillips head screwdriver to remove it. I did not have a snorkle on my 2 hilux's i just removed the plastic pipe i mentioned. For really deep water, put a blind infront of the radiator.
Their is nothing you can do to the 2.8 to more power out of it bar turbo, the extractors will help it breathe a bit better,just change oil every 5000km religously and oil filter every 10000km and you should get another 270000km out of it.
509575
Reply By: Member - Serendipity(WA) - Tuesday, Apr 23, 2013 at 07:19
My son has a mazda 2004 and while he was out 4x4 driving and needed to cross water on the track. It was only about up to the hubs but he hit it a bit hard and splashed water into the wheel arches and such. Bang - filled the air intake which happens behind the headlight in the wheel arch and stopped the engine with major damage to the turbo.
We emptied all the water out then and there but the turbo had bend all the fins over so it need replacing.
Not really that much water. If you can afford it then they are a good idea in Australia even for getting cleaner air from higher up.
Serendipity
509581
Reply By: Wayne (NSW) - Tuesday, Apr 23, 2013 at 08:31
oliver,
Just to add a few more points about a
snorkel for the Hilux.
When a
snorkel is fitted to the 2.8 motor it always resinated as though the dash was going to fall off. There was no real fix to the problem except for fitting a turbo.
$100 of eBay for a
snorkel is cheap, and unless you are going to fit the
snorkel yourself it will cost you more to fit it. The trouble with some of the cheap snorkels is that they do not fit the guard and the template that is supplied is not that good.
If you are going to fit a
snorkel for water crossings, which most drivers do, don't forget to fit diff breathers.
Wayne
509587
Follow Up By: Hilux fan - Thursday, Apr 25, 2013 at 15:58
I had a Safari
snorkel fitted to my 1993 Hilux and it resonated when fitted. I fixed it myself with the judicious wedging of bits of rubber mat, plus ensuring all the attachment screws were tightened up. Definitely improved the power and economy, so worthwhile just for that.
787752
Reply By: Michael ( Moss Vale NSW) - Tuesday, Apr 23, 2013 at 18:00
Don't buy a cheap
snorkel, they crack, don't usually fit the guard, the brass inserts pull out and many of them are made up of fiddly bits that u have to make sure you seal up properly. Buy a genuine or Safari or a
well known brand. Probably the cheap ones have not been tested for sufficient flow! Ebay is a good place to look for a quality bargain. Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
509618
Reply By: Member - KEITH W (QLD) - Tuesday, Apr 23, 2013 at 18:15
yes, get a
snorkel
509620
Reply By: Tonyfish#58 - Tuesday, Apr 23, 2013 at 19:01
Water
If you do stuff like this, then yes :-)
Cheers Tony
509623
Follow Up By: edwin - Wednesday, Apr 24, 2013 at 11:07
Hi Tony, is that the track to
lookout point, that some long crossing from memory,crocs too apparently , I chickened out of that one due to no
snorkel.
Ed
787597
Follow Up By: Tonyfish#58 - Wednesday, Apr 24, 2013 at 17:29
Edwin - You are correct
RegardsTony
787643
Reply By: Member - PJR (NSW) - Wednesday, Apr 24, 2013 at 11:20
Before we purchased a 4WD we researched the types of terrain and crossings that we may encounter. The one crossing that convinced me to get a
snorkel was Nolans on the tele track on
Cape York. When we crossed it the water was lapping over the bonnet. Maybe I could have disconnected the inlet to the air filter etc etc. But it was so easy just to stick the water blind on (two straps to the mirrors) and just drive across.
We are happy that we did. Less dust into the filter as
well when on the dirt roads and tracks.
A bit like insurance I suppose. Some never have accidents. Some do. We chose to fit the
snorkel as insurance. Happy.
Phil.
509659
