roof stabilizers
Submitted: Tuesday, Apr 09, 2013 at 14:49
Mike S2
Hi guys,I have a jayco swan outback and on a couple of camps have noticed swaying of the roof section in windy conditions,the hollow steel risers that support the roof could easily bend if a gust came thru,my question is has anyone designed or found an internal stabilizer to beef up these risers in a triangular bracing form,any comments appreciated,regs,Mike
Reply By: HGMonaro - Tuesday, Apr 09, 2013 at 16:51
the linked item has Specifications :
•Closed 335mm.
•Opened 560mm.
Might be suitable for a pop-top, but can't see them working for a wind-up.
I carry 4 bits of pine (would need to measure but maybe 40x20mm cross section) cut to the correct length that fits beside the riser (on the outside). Have put them up on a couple of real windy nights.
They did come in handy one night when a fellow camper was attempting to raise their roof and the winch failed. We lifted the roof in stages and jambed these in to keep it up so they could sleep in it.
508580
Reply By: Marksom - Wednesday, Apr 10, 2013 at 08:29
Hi Mike , know exactly what your talking about, had Jayco Dove, same but shorter..also when you put awning or annexe out pulls side ways a bit.....I screwed ss saddle to 4 corners of roof into thick side material, then on windy camps anchored these to ground pegs, strong ones, with no spring, just adjust till riser tubes are straight Mark from
Ballina....now got Expanda.
508625
Reply By: dublediff - Thursday, Apr 11, 2013 at 17:16
I had a golf camper for many years, had similar concerns in the flinders rangers and
cook town, the van was really rocking, but no damage at all. They do have some lateral movement
in the wind, just relax. The wind in the flinders was actually lifting the bed end of my brother camper trailer off the ground with the kids on it! Many caravans and campers packed up in the middle of the gift and left...we just rode it out.
508746
